Equilibrium Constant and Gibbs Energy
4 replies · 3K views · last reply
laser1
N/A
N/A
We have that ##\Delta G = -RT\ln K##. This is in my lecture notes. However, it does not specify whether ##K## is ##K_c## or ##K_p##. Fair enough, I assumed that it could be both. However, when writing out the definitions of ##K_p## and ##K_c##, and using the fact that ##P=CRT##, where ##C## is the concentration, defined as ##n/V##, I noted the fact that ##K_p=K_c(RT)^{\Delta n}##.
So let's say $$\Delta G = -RT\ln K_p = -RT\ln K_c$$ It is clear that this equation cannot be true, right? As you get an extra factor of ##-RT\Delta n \ln(RT)## on one side. Where am I going wrong?
You are going wrong in a number of places. First of all, in your initial equation, you should have ##\Delta G^0##, the free energy change between the standard states of reactants and products. Secondly, in your equation, you should have ##K_P##, nor ##K_C##. Third, the expression for ##K_P## should involve only partial pressures (in bars) and not ##\Delta n##.
Thanks for the reply.
1. Fair enough.
2. Okay, so the ##K## in the formula refers to ##K_p##, NOT ##K_c##. Can you provide some insight on this? Or is it just by definition.
3. Are you sure? book states that ##K_p=K_c(RT)^{\Delta n}##.
1. Fair enough.
You need to review the derivation of the relationship between ##\Delta G^0## and ##K_P##
Your relationship between Kp and Kc is correct, if R is expressed in Joules/mole-K.
Note that K in the Delta G equation involves the activities, not the concentrations or partial pressures. In ideal systems #c/c^o=p/p^o#
