Equilibrium of a compound object
  • Thread starter Thread starter nokia8650
    Equilibrium
The discussion focuses on the equilibrium of a closed container C, consisting of a hollow hemispherical bowl and a circular disc lid, both of radius a and made from the same material. The center of mass of the container is determined to be at a specific distance from the center O of the disc. Additionally, the angle made by the line PO with the horizontal is calculated, emphasizing that the line of action of the weight must pass through both the center of mass and the point of contact with the horizontal plane, due to geometric constraints.
  • Understanding of center of mass calculations
  • Familiarity with geometric properties of circles and spheres
  • Knowledge of equilibrium conditions in physics
  • Basic principles of mechanics related to forces and moments
  • Study the principles of center of mass in composite bodies
  • Learn about equilibrium conditions and stability in physics
  • Explore geometric properties of hemispherical shapes
  • Investigate applications of these concepts in engineering design
Students of physics, mechanical engineers, and anyone interested in understanding the principles of equilibrium and center of mass in composite objects.
nokia8650
A closed container C consists of a thin uniform hollow hemispherical bowl of radius a, together with a lid. The lid is a thin uniform circular disc, also of radius a. The centre O of the disc coincides with the centre of the hemispherical bowl. The bowl and its lid are made of the same material.
(a) Show that the centre of mass of C is at a distance from O.
The container C has mass M. A particle of mass M is attached to the container at a point P on the circumference of the lid. The container is then placed with a point of its curved surface in contact with a horizontal plane. The container rests in equilibrium with P, O and the point of contact in the same vertical plane.
(b) Find, to the nearest degree, the angle made by the line PO with the horizontal.
The solution to part b is shown below:
http://img196.imageshack.us/img196/3603/39197560.th.jpg
My question is, the solution has the line of action of the weight passing through O - why does this have to be the case; surely this assumes that O to the point of contact with the surface below is a radius on which the combined centre of mass lies - I don't see why this is essential. Thanks.
Thanks
Hi nokia8650! :smile:
Because that's what balancing is …
the weight must go through both the c.o.m. and the point of contact.
But the c.o.m lies on a radius, and that radius must go through the point of contact, because of the geometry. :wink:
Thanks for the reply. Surely O - is not the point of contact - O is the centre of the upper disc.
Thanks
Yes, O lies on every radius …
if C is the c.o.m and P is the point of contact, then the weight must go along the line CP,
and CP must be a radius because of the geometry,
and so O also lies on CP, and the weight goes through O. :smile:
  • · Replies 18 ·
