Equilibrium of Charges using Coloumbs Law
The discussion centers on calculating the equilibrium position of an electron influenced by two point charges: a negative charge of -0.5 µC at the origin and a positive charge of 12 µC located at (1 m, 0.5 m). The equilibrium condition is established by equating the forces acting on the electron from both charges, using Coulomb's Law, F = k * (q1 * q2) / r². The user successfully sets up the equations for the forces but requires assistance in solving for the distances and coordinates of the equilibrium position.
  • Coulomb's Law for electrostatic force calculations
  • Basic trigonometry for distance calculations
  • Understanding of point charges and their interactions
  • Ability to solve quadratic equations
  • Study the derivation and applications of Coulomb's Law in electrostatics
  • Learn how to solve quadratic equations in the context of physics problems
  • Explore graphical methods for visualizing forces and equilibrium positions
  • Investigate the concept of electric field and potential in relation to point charges
Students studying physics, particularly those focusing on electrostatics, as well as educators and anyone interested in understanding the dynamics of point charges and equilibrium in electric fields.
gc33550
A point charge of -0.5 C is located at the origin. A second point charge of 12 C is at x = 1 m, y = 0.5 m. Find the x and y coordinates of the position at which an electron would be in equilibrium.
F=k*((q_1*q_2)/r^2)
I know that I will have to find the two forces that the point charges will have on the electron at some arbitrary point that we will eventually solve for. We then set those two forces equal to each other and then solve for the distance. Once we have the distance we can easily solve for the components using simple trig... I must be having a problem setting up my equations any help?
Start by showing what you have done so far. Your strategy is OK, can you do what you said you should do and write some equations down? Also drawing a picture with where you think the electron might be located should help.
Hi gc33550! :smile:
I'm not sure whether you've noticed that this is a one-dimensional problem …
then just use the usual 1/r2 formula, using a different r for each charge, of course. :wink:
tiny-tim said:
Hi gc33550! :smile:
Thanks for your Input. Yes I realize it is one dimensional so hear is what I have so far:
(I will define 1 as the negative charge and 2 as the positive and e will be the electron)
F_1e=k*((-.5muC*e)/R_1e^2)
F_2e=k*((12muC*e)/R_2e^2)
to find equilibrium:
F_1e= F_2e
I am then left with:
((-.5muC)/R_1e^2)=((12muC)/R_2e^2)
I know the distance of R1 to R2 because of trig. So then R_2e=(R_1e+1.12m)
As far as where the electron is it would be in the third quadrant along a straight line with the other two point charges I know it will have to be close to the negative point charge to balance out the great attractive force of the positive point charge.
Once again thanks to both of you.
Hi gc33550! :smile:
(have a mu: µ and try using the X2 and X2 tags just above the Reply box :wink:)
(your equations are almost unreadable, but I think I follow that bit :redface: …)
ok, now substitute for R2 in the first equation, put everything on top, and you have a quadratic equation in R1 :smile:
  • · Replies 30 ·
  • · Replies 32 ·
