Equivalence Classes: Unique Unit Circle Rep.
7 replies · 4K views · last reply
hitmeoff
Let S := ([tex]\Re[/tex] x [tex]\Re[/tex] \ {(0,0)}. For (x,y), (x',y') [tex]\in[/tex] S, let us say (x,y) ~ (x',y') if there exists a real number [tex]\lambda[/tex] > 0 such that (x,y) = ([tex]\lambda[/tex]x',[tex]\lambda[/tex]y'). Show that ~ is an equivalence relation; moreover, show that each equivalence class contains a unique representative that lies on the unit circle (i.e., the set of points (x,y) such that x2 + y2 = 1).
I know in order to show that something is an equivalence relation if the following 3 properties hold
reflexive: a ~ a for all a [tex]\in[/tex] S
symmetric: a ~ b implies b ~ a for all a,b [tex]\in[/tex] S
transitive: a ~ b and b ~ c implies a ~ c for all a, b, c [tex]\in[/tex] S
and for an equivalence relation ~ the equivalence class as the set {x [tex]\in[/tex] : x ~ a}
What I don't get is, if there is no operation defined how do we show equivalence? Or is the operation scalar multiplication?
Im not sure where to go from here, especially showing that the solution to the unit circle is in the equivalent class.
This is easy, so I think you are just confused by the fact that the members of your space are ordered pairs instead of numbers. So instead of showing that a ~ a, say, you have to show that for arbitrary (x,y), we have (x,y) ~ (x,y).
Hint: can you think of a [tex]\lambda[/tex] such that [tex](x, y) = (\lambda x, \lambda y)[/tex]?
(I told you it was easy.)
well for the reflexive property if [tex]\lambda[/tex] = 1 which is > 0, then (x, y) = (1[tex]\cdot[/tex]x, 1[tex]\cdot[/tex]y) so that holds.
But now for symmetric:
If (x, y) = ([tex]\lambda[/tex]x', [tex]\lambda[/tex]y') then ([tex]\lambda[/tex]x', [tex]\lambda[/tex]y') = (x,y), so (x,y) ~ ([tex]\lambda[/tex]x', [tex]\lambda[/tex]y') implies ([tex]\lambda[/tex]x', [tex]\lambda[/tex]y') ~ (x, y) but is this "showing it"?
and for the part: "moreover, show that each equivalence class contains a unique representative that lies on the unit circle (i.e., the set of points (x,y) such that x2 + y2 = 1)."
Could we say:
For any (x,y) in R x R there exist a [tex]\lambda[/tex] s.t x2 + y2 = [tex]\lambda[/tex]2, or (x/[tex]\lambda[/tex])2 +(y/[tex]\lambda[/tex])2 = 1.
If x' = x/[tex]\lambda[/tex] and y' = y/[tex]\lambda[/tex] then (x,y) = ([tex]\lambda[/tex]x', [tex]\lambda[/tex]y')
So for any equivalence class [(x,y)] there is a unique representative (x',y') s.t. x'2 + y'2 = 1
Not quite. If
[tex]x' = \lambda x[/tex],
then what is x in terms of x'?
For the part about the representative on the circle, you are OK.
I have the same problem. How would do you symmetric and transitive? Do you suppose to use integral?
There is no reason to use calculus at all!
Here, we say that (x, y) is equivalent to (u, v) if and only if [itex](x, y)= \lambda(u, v)[/itex] for some non-zero number [itex]\lambda[/itex].
If [itex]x= \lambda u[/itex] and [itex]y= \lambda v[/itex], then [itex]u= (1/\lambda)x[/itex] and [itex]v= (1/\lambda) y[/itex]. Since [itex]\lambda> 0[/itex], [itex]1/\lambda> 0[/itex].
Similarly, if (x, y) is equivalent to (u, v) and (u, v) is equivalent to (a, b), then [itex]x= \lambda_1u[/itex] and [itex]y= \lambda_1v[/itex] for some [itex]\lambda_1> 0[/itex] and [itex]u= \lambda_2a[/itex] and [itex]v= \lambda_2b[/itex] for some [itex]\lambda_2> 0[/itex].
It should be obvious then that [itex]x= \lambda_1(\lambda_2a)[/itex][itex]= (\lambda_1\lambda_2)a[/itex] and [itex]y= \lambda_1(\lambda_2 b)= (\lambda_1\lambda_2)b[/itex] so that [itex]x= \lambda a[/itex] and [itex]y= \lambda b[/itex] with [itex]\lambda= \lambda_1\lambda_2> 0[/itex].
