- 3,768
- 1,982
It's in the right ballpark.fizixfan said:I tried using your formula V^2 = GM/r (assuming V = (GM/r)^0.5) where
G = 6.67*10^-11 m^3/kg s^2
M = 5.9722*10^24 kg
r = 6,367,444.7 m
and the result was 7,909.47 m/s ?
If I use V = (2GM/r)^0.5, I get Vesc = 11,185.68 m/s = escape velocity
So, is this the correct calculation - that an object dropped from a height of one radius above Earth's surface will reach the surface at a speed of 7,909.47 m/s? Or am I using the wrong units or doing something else wrong?
Please note: I'm no longer trying to "prove" something based on an assumption that violates the laws of physics. I'm here to learn. Thanks.
However, I will point out a couple of things about your calculation. One, since you only carry G out to three significant digits, it really makes no sense to carry M and r out to more than that same number of significant digits. Also, if accuracy is important, it is better to use 3.986004418e14 for GM, as we know it to a greater accuracy than we do for either the mass of the Earth, or G. In addition the Earth, being an oblate spheroid has an radius that varies from 6356.8 to 6378.1 km. So the value you give is close to the average between these two, but the actual impact velocity would depend on the actual radius at the point of impact.
