What is the vector equation for escape velocity?
The vector equation for escape velocity can be expressed as v = (sqrt(2GM)/r)−hat{r}, where G is the gravitational constant, M is the mass of the celestial body, and r is the distance from the center of the body. Escape velocity is technically a scalar quantity, often referred to as "escape speed." The direction of escape velocity is flexible, provided the trajectory does not intersect the surface of the celestial body, which depends on the distance from the center and the radius of the body.
  • Understanding of gravitational physics and the concept of escape velocity
  • Familiarity with vector mathematics and notation
  • Knowledge of celestial mechanics, particularly three-body problems
  • Experience with programming simulations involving gravitational interactions
  • Research the derivation of escape velocity in gravitational fields
  • Explore vector calculus applications in celestial mechanics
  • Learn about numerical methods for simulating three-body problems
  • Investigate the effects of varying mass and distance on escape trajectories
Students and professionals in physics, astrophysics, and engineering, particularly those involved in simulations of gravitational systems and celestial mechanics.
rich86
hi, i have been looking for a while but stillnot managed to find a vector equation for the Escape Velocity. i know the escape velocity is:
v=sqrt(2GM/r)
i would like a vector form to extend a program i am making for a three body gravitational problem
many thanks
richard
Astronomy news on Phys.org
Would it not just be \bold{v}=\frac{\sqrt{2GM}}{r}\hat{r}?
The term "escape velocity" is a bit of a misnomer: it really should be called "escape speed" because it truly is a scalar quantity.
thanks, that helps a lot...
..but makes my project harder in finding the right direction for the escape velocity!
The right direction is any direction, as long as the resulting trajectory doesn't intersect the surface of the body you are trying to escape from. Whether any given trajectory intersects the surface depends a couple of factors, The distance you are from center of the body and the radius of the body. If you are sitting right above the surface of the body you have a smaller range of possible directions that do not result in collision with the surface than you would if you started some greater distance away from the body.
  • · Replies 17 ·
  • · Replies 86 ·
