Estimate the Dielectric Breakdown of Air
The dielectric breakdown of air can be estimated using the formula E = V/d, where V is the voltage and d is the distance. In this case, with a voltage of 5 kV and a spark length of 1 cm, the electric field Eair is calculated to be approximately 5 x 105 V/m. It is important to note that the electric field is not uniform; it is significantly stronger near the wire's tip, which is where breakdown occurs. This estimation aligns with established values for air breakdown under similar conditions.
  • Understanding of electric fields and voltage concepts
  • Familiarity with capacitor behavior and charging
  • Basic knowledge of dielectric materials and breakdown phenomena
  • Proficiency in using the formula E = V/d for electric field calculations
  • Research the factors affecting dielectric breakdown in various gases
  • Explore the impact of electrode geometry on electric field distribution
  • Learn about high-voltage safety measures in electrical engineering
  • Investigate the applications of dielectric breakdown in circuit design
Electrical engineers, physics students, and professionals involved in high-voltage applications or capacitor design will benefit from this discussion.
flannabhra
A capacitor is charged to V = 5 kV.
A wire is then connected to one plate and is slowly connected to the other. Before actually touching the plate, a spark of length l = 1 cm shoots from the wire to the plate. Using this information, estimate the dielectric breakdown of air, which is the electric field Eair required to generate a spark in air.
E = \frac{V}{d}
E = \frac{V}{d} = 5 * 10^5 \frac{V}{m}
This is about as good an estimate as you can get.
However, realize that the E field is not constant between the wire and the plate. In fact, the E field at a point like the end of your wire will be very much larger than V/h, so breakdown most probably occurs at and near the wire's tip.
But your estimate is as good as anyone else's, under the circumstances.
  • · Replies 21 ·
  • · Replies 17 ·
