Estimate the maximum initial velocity
To estimate the maximum initial velocity of a tennis ball, the discussion emphasizes using the equations of motion for both vertical and horizontal components. The vertical motion equation accounts for gravity, while the horizontal motion remains unaffected by acceleration. Participants suggest measuring the height from which the ball is thrown and using simultaneous equations to solve for time and initial velocity. The conversation also highlights the importance of throwing the ball horizontally for accurate calculations. Practical trials are encouraged to validate theoretical findings.
Aquaticus
Hi I need some help with this question:
Estimate the maximum initial velocity you can achieve with a tennis ball
I thought of using the maximum range formula: R=v2/g but doesn't that imply to the fact that I'm throwing at an angle of 45 degrees?
Please help me, I really want to solve this problem, thanks in advance!
Throw the ball so it leaves your hand directed horizontally. Gravity will pull it downwards as it travels away. Write down the equations of motion that might be useful in this exercise.
Hi, thanks for the reply, these are the equations of motion:
How do I know which one to use and how to I motivate my answer?
u = initial velocity
V= final velocity
Thanks in advance!
(3) and (4) look useful.
Apply (3) vertically: you know s (the height above ground where your hand releases the ball), you know u, you know a. The only unknown is t.
Apply (4) horizontally.
Solve the equations simultaneously to determine t, the time that the ball was in flight.
(If you had a movie camera set up, you could film the flight of the ball and deduce from this how long the ball was in the air, and then compare it with your calculation.)
How about equation 5?
The acceleration is local acceleration of gravity g. At this point one must remember that while these quantities appear to be scalars, the direction of displacement, speed and acceleration is important. They could in fact be considered as uni-directional vectors. Choosing s to measure up from the ground, the acceleration a must be in fact −g, since the force of gravity acts downwards and therefore also the acceleration on the ball due to it.
At the highest point, the ball will be at rest: therefore v = 0. Using the fifth equation, we have:
s= {v^2 - u^2}/{-2g}.
Substituting and cancelling minus signs gives:
s = {u^2}/{2g}.
And therefore I can calculate the initial velocity u.
Thanks in advance!
(5) is useful only for the vertical component. You are throwing the ball horizontally, so (5) is of no use.
You said that I know u which is the initial velocity, that is the component I'm looking for.
You are trying to find u in the horizontal analysis. In the vertical analysis, u is known and is 0, because the ball is being thrown horizontally.
Is a=g in equation 3? And how do I simultaneously determine t? Is it a simultaneous equation? Equation 4 which is the horizontal analysis does not contain u which is the initial velocity, how do I determine the initial velocity then?
Yes, for the vertical motion.
Solve 2 equations simultaneously; there being only one unknown there, t.
The horizontal u is what you are trying to find. :smile:
I really do not understand what you mean, the equations are:
Equation three is the vertical on while equation four is the horizontal one,
u= initial velocity
v= final velocity
If I'm throwing something horizontally, how do I determine the initial velocity. Equation four states only the final velocity and u=0 in equation three.
No they're not. (3) and (4) are one and the same. For vertical motion, a=g. For the horizontal motion, a=0. The motion we are concerned with here involves both a horizontal component, and a vertical component. They need to be considered separately. Gravity affects only the vertical component. Nothing affects the horizontal component, so horizontal velocity remains unchanged (until the ball hits the dirt). You can use any equation anywhere, so long as you use the applicable value/s.
That's the whole exercise here. We've made that your maximum speed of throwing the ball. That's the only unknown, provided you do measure the distance the ball goes before it hits the ground.
Go back to my first post. That tells you how to go about finding u (horizontally).
So how do I really find the initial velocity with regards to equation 3 and 4. I really do want to understand this problem and solve it. Sorry if I'm asking too much, I got a bit confused.
I don't understand how I shall deal with the vertical analysis and the horizontal analysis and how to use equation (3) and (4) to determine the initial velocity. Please help!
Thanks in advance!
Are you there?
Equation 3 which should be applied vertically contains u = initial velocity
Equation 4 which should be applied horizontally contains v = final velocity
How can I determine u which is the initial velocity in equation 4 that does not contain u (initial velocity).
Thanks in advance!
Oh, I hadn't distinguished the u from the v. Forget about (4), apply (3) separately for both horiz and vert components.
horiz: you measure s, need to find u, know a=0, and leave t as t.
vert: you measure s (vert distance from your hand to the ground as you release the ball), u=0, a=g, and leave t as t.
Rearrange one of these as t=...
and substitute that for t into the other equation. The only unknown then is u, that's the horizontal speed which you are wanting to determine, so you can rearrange the equation to find u.
Are you doing practical trials of this on a playing field? If so, repeat half a dozen times, and see how well it works out. The key is to throw the ball precisely horizontally.
The question is a bit vague. Do they mean the maximum velocity as might be produced by hitting it with a racket? By throwing it? Firing it out of a canon?
Is that the entire wording of the original question?
