Estimating integral with Maclaurin series
The discussion revolves around approximating the integral of sin(7x^2) using the first two terms of its Maclaurin series. Participants explore the application of the Maclaurin series in the context of calculus, specifically focusing on series expansion and integration techniques.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Problem interpretation
  • Participants discuss the correct application of the Maclaurin series, with some questioning the evaluation of derivatives and the significance of non-zero terms. There are attempts to clarify the process of constructing the series and integrating it term by term.
The discussion is active, with participants providing guidance on the correct interpretation of the problem and the steps involved in using the Maclaurin series. There is recognition of the challenges in achieving accurate approximations with limited terms, and some participants are exploring the implications of using more terms for better accuracy.
Participants note the importance of adhering to the problem's requirement to use only the first two non-zero terms of the series, which raises questions about the potential errors in approximation when fewer terms are used.
lxman
Assume that sin(x) equals its Maclaurin series for all x. Use the first two terms of the Maclaurin series for sin(7x^2) to approximate the integral:
[tex]\int_{0}^{0.77}sin(7x^{2})\ dx[/tex]
If I understand correctly, a Maclaurin series is just a Taylor series centered at 0. Therefore, my first two terms would be:
[tex]sin(7(0)^{2})[/tex]
and
[tex]14(0)^{2}cos(7(0)^{2})[/tex]
I feel like I'm getting off on the wrong foot right away.
Help anyone?
your first derivative is slightly off it should just 14xcos(7x^2), evaluated at zero. which just equals zero.
and
Help anyone?
Yes you are doing this correctly so far except your second term should be
[tex]14(x) cos(7(x)^{2}) \right _{x=0}[/tex]
which of course gives the same result. But this could have messed you up with your next derivatives.
Now try to take a few more derivatives until you get some non zero terms. Don't forget about the product rule :wink:
The original problem statement says to use the first two terms of the Maclaurin series. So when I am constructing the series, I just basically throw away any terms with zero values, and the non-zero terms then become my series.
Is this correct?
One way to do this is to take the Maclaurin series for sin(x), then substitute 7x2 for x. Then integrate that tern by term.
Is this correct?
Yes, just use the first two non zero terms.
SammyS, your idea sounds MUCH simpler, but you would have to explain the details of implementation to me.
So, doing it the hard way - and yes, it gets a bit messy, so I won't post all the details.
I end up with the first two non-zero terms being term 2, which evaluates to 14, and term 6, which evaluates to -41160.
Dividing these with their factorials, multiplying by the x-a terms (which is just x, as a is zero) and simplifying, I end up with:
[tex]7x^{2}-\frac{343\ x^{6}}{6}[/tex]
Plugging in 0.77, I get a result of -7.764512728421
I know the actual value of the integral is about 0.3
I presume the error comes from the fact that I am only using two terms.
Am I correct?
I end up with the first two non-zero terms being term 2, which evaluates to 14, and term 5, which evaluates to -41160.
Am I correct?
But you have to integrate it first. You can't just plug in .77 before you integrate.
Okay, yep, missed that one completely.
Integrating gives me:
[tex]\frac{7x^{3}}{3}-\frac{49x^{7}}{6}[/tex]
Now, plugging in 0.77, I get -0.245385 which is much closer.
Again, I presume the error is from only using two terms.
Yes it is. If you had tried three terms, you would get a number even close, but above the correct answer.
Thank you all for your help.
Have a great day!
  • · Replies 16 ·
