How Does the Euler-Lagrange Equation Apply to Parametric Solutions?
  • Thread starter Thread starter Another
    Euler-lagrange
The discussion centers on the application of the Euler-Lagrange equation to parametric solutions, specifically addressing the definition of a function in the context of the equation y_x = (b+y)/(a-y)². The book presents a solution in the form y = y(θ(x)), which is derived from a clever substitution that simplifies solving the differential equation. There is a noted concern about the exponent in the equation, suggesting it should be 1/2 instead of 2. This substitution facilitates finding a parametric solution, expressed as y(θ) and x(θ), where θ serves as a parameter. The conversation emphasizes the importance of understanding these relationships in solving differential equations effectively.
Another
I am wondering about definition of a function
## F = \frac{(1+(y_x)^2)^{\frac{1}{2}}}{(y_1-y)^{\frac{1}{2}}}##
My question : I am wondering about definition of a function. when ##y_x = (\frac{b+y}{a-y})^2##
Why in this book is defined solution ##y = y(x)## in from ## y = y(θ(x))## . And have a relationship in the form
## y = \frac{1}{2} (a-b) - \frac{1}{2} (a+b) cosθ ## ?
_____________________________________________________________________________________________________________________________________
In this book is defined ## F = \frac{(1+(y_x)^2)^{\frac{1}{2}}}{(y_1-y)^{\frac{1}{2}}}##
The E-L equation in case F = ##F(y,y_x)## ===> ##F - y_x \frac{∂F}{∂y_x} = c## when c is constant.
The exponent should be 1/2 rather than 2.
This is just a very clever substitution that allows you to fairly easily find a solution of the differential equation, ##y_x = (\frac{b+y}{a-y})^{1/2}##. It yields a solution in parametric form: ##y(\theta)## ; ##x(\theta)##, where ##\theta## is a parameter.
TSny said:
The exponent should be 1/2 rather than 2.This is just a very clever substitution that allows you to fairly easily find a solution of the differential equation, ##y_x = (\frac{b+y}{a-y})^{1/2}##. It yields a solution in parametric form: ##y(\theta)## ; ##x(\theta)##, where ##\theta## is a parameter.
thank you very much
