Evaluate the limit of this harmonic series as n tends to infinity
The discussion centers on evaluating the limit of a harmonic series divided by \( n^2 \) as \( n \) approaches infinity. Participants analyze the application of L'Hôpital's Rule and express confusion over the derivation of the numerator, ultimately concluding that the limit approaches zero rather than one. They emphasize that the harmonic series grows slower than the polynomial denominator, leading to a limit of zero. The conversation highlights the importance of recognizing the growth rates of the numerator and denominator in limit evaluations. The final consensus suggests that the limit is indeed zero, contradicting the initial claim that it equals one.
Aurelius120
Evaluate $$\lim_{n\rightarrow \infty}\left(\frac{1+\frac{1}{2}+\frac{1}{3}+\frac{1}{4}+........\frac{1}{n}}{n^2}\right)^n$$
$$\lim_{x \to{+}\infty}{f(x)^{g(x)}}=e^{\left(\lim_{x \to{+}\infty}{(f(x)-1)\cdot g(X)}\right)}$$ $$\text{if}\lim_{n\rightarrow \infty}f(x)=1\text{ and } \lim_{n\rightarrow \infty}g(x)=\infty$$
To use the formula above, I have to prove that $$\lim_{n\rightarrow \infty}f(x)=\lim_{n\rightarrow \infty}\left(\frac{1+\frac{1}{2}+\frac{1}{3}+\frac{1}{4}+........\frac{1}{n}}{n^2}\right)=1$$
To prove so, I tried using L'Hopital's Rule:
$$\lim_{n\rightarrow \infty}f(x)=\lim_{n\rightarrow \infty}\frac{-1n^{(-2)}}{2n}$$ But this gives zero.
The numerator in the last expression is incorrect.
Why so ?
$$\frac{d\left(\frac{1}{1}+\frac{1}{2}+\frac{1}{3}+..........\frac{1}{n}\right)}{dn}=\frac{dn^{-1}}{dn}=-n^{-2}$$
##\frac{d\left(\frac{1}{1}+\frac{1}{2}+\frac{1}{3}+..........\frac{1}{n}\right)}{dn} \neq \frac{dn^{-1}}{dn}##
Rather,
##\frac{d\left(\frac{1}{1}+\frac{1}{2}+\frac{1}{3}+\frac{1}{n}\right)}{dn}=\frac{dn^{-1}}{dn}##
Rather,
Why is that ? Since the constants after that will also be zero?
Also even we go the other way:
$$\lim_{n\rightarrow \infty}f(x)=\lim_{n\rightarrow \infty}\left(\frac{1+\frac{1}{2}+\frac{1}{3}+\frac{1}{4}+........\frac{1}{n}}{n^2}\right)=\lim_{n\rightarrow \infty}\left(\frac{1}{n^2}+\frac{1}{2n^2}+\frac{1}{3n^2}+\frac{1}{4n^2}+........\frac{1}{n^3}\right)$$ which is still zero.
I don't see the point of using L'Hopital. The answer should be clear using a crude estimate for the partial sums of the harmonic series.
PS just try ##n = 2, 3 \dots ##, to see what's happening:
$$a(2) = \bigg (\frac{1 + \frac 1 2}{4}\bigg)^2 = \bigg(\frac{3}{8}\bigg)^2$$
$$a(3) = \bigg (\frac{1 + \frac 1 2 + \frac 1 3}{9}\bigg)^3 = \bigg(\frac{11}{54}\bigg)^3$$That sequence definitely does not converge to ##1##.
Good luck with proving that!
Because $$1+\frac{1}{2}+\frac{1}{3}+\frac{1}{4}+........\frac{1}{n} \neq const.+\frac{1}{n}$$
Actually,
$$1+\frac{1}{2}+\frac{1}{3}+\frac{1}{4}+........\frac{1}{n} = 1+\frac{1}{2}+\frac{1}{3}+\frac{1}{4}+........+\frac{1}{n-3}+\frac{1}{n-2}+\frac{1}{n-1}+\frac{1}{n}$$
Likes Mark44, Aurelius120 and pasmith
Well the solution involves somehow using the "relevant equations" formula. For which
$$\lim_{n\rightarrow \infty}f(x)=1$$ but
$$\lim_{n\rightarrow \infty}f(x)=\lim_{n\rightarrow \infty}\left(\frac{1+\frac{1}{2}+\frac{1}{3}+\frac{1}{4}+........\frac{1}{n}}{n^2}\right)$$$$=\lim_{n\rightarrow \infty}\left(\frac{1}{n^2}+\frac{1}{2n^2}+\frac{1}{3n^2}+\frac{1}{4n^2}+........\frac{1}{n^3}\right)=0$$
So that is a problem
It's not clear to me why you're rejecting what appears to be the correct answer. Should the original problem involve an nth root, rather than a power of n?
The question in the book is
The solution uses $$\lim_{n\rightarrow \infty}e^{\left(\frac{1+\frac{1}{2}+\frac{1}{3}+\frac{1}{4}+........\frac{1}{n}}{n^2}\right)\cdot n}$$
I figured the solution evaluated the part after 1 instead of the entire limit
That is why I wanted to show that limit was 1
If you're faced with this question in an exam, just answer 1. It's the only possible choice. The expression in the parenthesis is non-negative, so the only option is 1, meaning the parenthesis must equal 0.
  • Haha
Likes PeroK and Aurelius120
The limit is $$\lim_{n\rightarrow\infty}\left(\frac{H_n}{n^2}\right)^n=\lim_{n\rightarrow\infty}\frac{H^n_n}{n^{2n}}$$Where ##H_n## is the ##n##th harmonic number. The numerator grows much slower than the denominator and so the answer is just ##0##.
This is the given solution though
Take the natural log of both sides. Also this isn't the original limit as in the question.
I think ln(n) is an upper bound for the sum ##\Sigma_{i=1}^n \frac{1}{i}##. If so, the power is bound by ##\frac{ln(n)}{n}##, which goes to ##0## as ##n## goes to ##\infty##. (i.e., using that ##ln(e^n=n)##I experimented with powers of ##e; e^n; n=1,2,...## and this bound seemed to hold up. Obviously both sequences diverge, but ##ln(n)## does so much faster than the Harmonic series.
No. It's ##\ln(n)+\gamma## (where ##\gamma## is the Euler-Mascheroni constant). However, ##\ln n## is pretty close to the harmonic numbers so replacing the numbers with that function shouldn't change anything.
  • · Replies 20 ·
