Evaluating an indefinite integral by substitution
10 replies · 3K views · last reply
whatisphysics
Evaluate the indefinite integral.
I tried to use substitution.
I'm not so good with using the LaTex codes...so I attached a file I made in Word.
Thanks in advance!
  • Handwritten-style worked substitution of the integral of x^7 times e^(x^8) dx, setting u = e^(x^8), with steps through du/dx and the rewritten integral of u over e^(x^8) times 7x^7 du, ending in a stuck step.
iamalexalright said:
Try using u = x^8
The x^8 from e^(x^8) or x^7?
I don't understand your question
But besides a poor choice of u in your original solution you don't carry out the integral properly
With my choice of u (u = x^8) compute du/dx and show me the new integral
Okay, I've now ended up with
\\frac{1}{7}\\int\\frac{e^u}{x^7} du
You should show me the steps you take to get there!
plus use the carrot to show superscripts with LaTeX: e^{u}
What is the derivative of u = x^8 with respect to x?
Alright, the integral is:
[tex]\int x^{7}e^{x^{8}}dx[/tex]
I'll choose u = x^8
[tex]du = 8x^{7}dx[/tex]
Here is where you had an issue before, notice that in the original integral I do have x^7dx in it ! This implies I don't need to divide by x^7, I just use the substitution:
[tex]\frac{1}{8}du = x^{7}dx[/tex]
Can you finish it from here?
I'll choose u = x^8
Okay, I tried what you said. Can you check it, thanks! And how do I go on from there, I'm not very good at this, but I still want to learn!
  • Handwritten substitution work: e^(x^8) as u, u = x^8, dx = du/(8x^7), the integral of (x^7 e^u)/(8x^7) du, then = (1/8) integral of e^(x^8) + C.
[tex]\begin{aligned}<br /> dx &= \frac{du}{8x^7} \\<br /> \int \frac{x^{7} \cdot e^u}{8x^{7}}dx &= ...<br /> \end{aligned}[/tex]
This is the 2nd time I saw someone work a u-substitution this way. Why isolate dx? I think it makes things complicated. Solve for 'an expression in the integral that contains dx' instead, like this:
[tex]\begin{aligned}<br /> u &= x^8 \\<br /> du &= 8x^7 dx \\<br /> \frac{1}{8} du &= x^7 dx<br /> \end{aligned}[/tex]
(because x7 dx appears in the integral)
So,
[tex]\int x^{7}e^{x^{8}}dx = \frac{1}{8}\int e^u du = ...[/tex]
Thank you both so much!
And to eumyang, I don't understand, I thought it would be easier to isolate the dx, because you can simply just substitute the dx, isn't that right?
Anyway, thanks again!
