Evaluating Contour Integral w/ Multiple Singularities
The discussion revolves around evaluating a contour integral involving multiple singularities, specifically the integral \(\oint\frac{dz}{z^{2}-1}\) over the contour defined by \(|z| = 2\). Participants explore the implications of having singularities at \(z=1\) and \(z=-1\) within the contour and the limitations of their current understanding of contour integration techniques.
  • Participants discuss the possibility of using partial fractions to simplify the integral and whether Cauchy's Integral Formula can be applied to each singularity individually. There are questions about the validity of these approaches given the presence of multiple singularities.
The discussion is ongoing, with several participants offering suggestions and exploring different interpretations of the problem. Some participants express uncertainty about the application of Cauchy's Integral Formula and the implications of the results they are obtaining, particularly regarding the integral evaluating to zero.
Participants note that they have not yet learned the residue theorem, which limits their methods for evaluating the integral. There is also mention of confusion regarding the logarithmic functions involved in the context of complex analysis.
newmike
Contour integral with multiple singularities inside domain without residue theorem??
Evaluate
[tex]\oint\frac{dz}{z^{2}-1}[/tex]
where C is the circle [tex]\left|z\right|[/tex] = 2
Just learned contour integrals, so not much.
Ok to use Cauchy's Integral formula (if applicable)
Cannot use reside theorem as we haven't learned that yet
I've tried this a few different ways...
Anyway, it is clear that there are two singularities: z=1 and z=-1, and both of which are inside the contour. Because of this, I don't think I can use Cauchy's Integration formula.
By attempting the integral the long way and writing out partial fractions, I've arrived at:
[tex]\frac{1}{2}\oint \frac{2ie^{it}dt}{2e^{it}-1}-\frac{1}{2}\oint \frac{2ie^{it}dt}{2e^{it}+1}[/tex]
where each integral is integrated over 0 to 2*pi
which is where I'm stick. I see that I can turn this into (using substitution):
[tex]\frac{1}{2}ln(\frac{2e^{it}-1}{2e^{it}+1})[/tex]
evaluated on 0 to 2pi which ends up with zero since it's not analytic. It seems I are ignoring the singularities here...
I have a gut feeling the answer shouldn't be zero... Any suggestions?
Thanks,
-Mike
How about splitting 1/(z^2-1) using partial fractions into the sum of two functions which each have only one singularity?
I think that is what OP already did.
Well I don't understand how that works since the domain still has two singularities. Are you suggesting apply cauchy's integral formula one at a time. Is that valid? I'm new to the topic and trying to get my head around it. I'll try it out to see what I get.
I believe the problem is that the function should be Log(z) not ln(r)
Log(z) = ln |r| + i arg(z)
Ok, let me see if that changes things. Thanks.
Yes, it does look like the OP already did partial fractions. But my version of the Cauchy integral formula tells my how to integrate 1/(z-1) without using a contour parametrization. I don't see why you need to use one.
Btw that should read
log(z) = ln|z| + iarg(z)
not
log(z) = ln|r| + iarg(z) .
Sorry for the mistake :)
I edited my post. I didn't read the post completely myself :)
But following your suggestion would also be useful to OP.
EDIT
The question as not adressed to me but yes it is valid.
not
Ok, I used this and still got zero.
I'm going to try use cauchy's integral formula on each one as you both are suggesting. Thanks again.
If you get zero again, I think you are on the right track.
Anyway follows Dick suggestion it is a better one. I gave you the suggestion so that you didn't have to rework anything.
The zero is because the sum of the singularities "cancel" out.
Thanks for all the help guys,
I applied cauchy's integral formula on both integrals and I also got zero.
Using: [tex]\oint\frac{dz}{z-1}[/tex]
I let f(z)=1, and f eval'd at the singularity is obviously f(1)=1, so I said
[tex]\oint\frac{dz}{z-1}[/tex] = 2[tex]\pi[/tex]i(1) = 2[tex]\pi[/tex]i
Likewise, I got the same answer for the other integral because again f(z)=1 so f(-1)=1.
Altogether:
1/2 * 2 pi i - 1/2 * 2 pi i = 0
Anything noticeably wrong??..or should I just accept the fact that the answer is indeed zero ;) Thanks again!
Accept it :).
Ok I'll accept it ;)
That makes sense. Now I feel more confident with the result of zero.
Thanks again, both of you, I've gone crazy over this one problem!
Take care,
-Mike
