Evaluating Operators: ABF(x) and BAF(x)
  • Thread starter Thread starter Pruddy
    Operators
The problem involves evaluating the operators A and B applied to the function f(x) = xe^(-ax), specifically calculating ABF(x) and BAF(x) to determine if the operators commute.
  • Exploratory, Assumption checking
  • Participants discuss the evaluation of the operators and the implications of the results regarding commutation. There are suggestions to clarify the notation and ensure that the evaluations are presented clearly.
Some participants have provided feedback on the original poster's calculations, indicating that while the approach seems reasonable, there are suggestions for improving clarity and ensuring the evaluations are distinct. There is no explicit consensus on the correctness of the original poster's conclusion about commutation.
The discussion includes a note about the assignment's expectations for evaluating the operators separately and the importance of clearly indicating whether the results equal zero.
Pruddy
Given the operator A = d/dx and B = x and the function f(x) = xe^(-ax)
evaluate : ABF(x) and BAF(x)
Do these operators commute (yes/No)
[A,B]F(x) = ABF - BAF = 0 ; means they commute
=d/dx(x^2e^-ax) - x d/dx (xe^-ax)
=2xe^-ax - ax^2e^-ax - xe^-ax + ax^2e^-ax
= 2xe^-ax - xe^-ax
No they do not commute [B,A]F(x) = BAF - ABF = 0
= x d/dx(xe^-ax) - d/dx (x^2e^-ax)
= xe^-ax - x^2ae^-ax - 2xe^-ax + x^2ae^-ax
= xe^-ax - 2xe^-ax
They do not commute...I was checking to see if my answer was right. Thanks in advance...
Looks good.
Seems reasonable - but needs a cleanup.
You should either keep the =0 all the way down (using implied signs on the left of each line) or leave it off the first line.
You need to comment that the last line does not equal zero (or that it is false if you kept the =0 part).
The assignment expects you to evaluate ABF and BAF separately and notice that they are not the same.
Thanks you all so much for your feedback. I am very grateful:).
GOD bless...
  • · Replies 27 ·
  • · Replies 22 ·
