What is the Limit of f(x) as x Approaches Infinity?
  • Thread starter Thread starter longrob
    Limit
The limit of the function f(x) = (e^x - 1) / (1 - 2e^x + 2e^(2x)) as x approaches infinity is evaluated to be (1/2)e^(-x). The discussion reveals that while the initial approach yielded a limit of 0, the correct interpretation involves identifying the dominant terms in both the numerator and denominator. The participants clarify that the question pertains to the long-term behavior of the solution to a differential equation, emphasizing the need to demonstrate that the limit of f(x)/g(x) approaches 1, where g(x) is the dominant term.
  • Understanding of limits in calculus
  • Familiarity with exponential functions and their properties
  • Basic knowledge of differential equations
  • Experience with asymptotic analysis
  • Study the concept of dominant terms in limits
  • Learn how to apply L'Hôpital's Rule for evaluating limits
  • Explore asymptotic behavior of functions in calculus
  • Investigate the relationship between differential equations and their long-term solutions
Students in applied mathematics, particularly those studying calculus and differential equations, as well as educators looking to clarify concepts related to limits and asymptotic analysis.
longrob
Evaluate the limit of the following as x approaches infinity
\frac{e^{x}-1}{1-2e^{x}+2e^{2x}}
\frac{e^{-x}-e^{-2x}}{e^{-2x}-2e^{-x}+2}
which gives 0/2=0 as x approaches infinity, but apparently this is wrong.
Why do you think it's wrong? I think it's right.
Because I am told the answer is \frac{1}{2}e^{-x}
The limit of (1/2)e^(-x) as x->infinity is 0. Are they actually asking for the asymptotic behavior or the limiting behavior? Not the limit?
The question doesn't explicitly ask for the limit, I just assumed that's what I had to do. This is an applied maths course, not analysis. The question is asking for the long term behaviour of the solution to a differential equation...
in case I'm not being clear, the expression I posted initially is the general solution to a DE problem that I obtained (so it might be wrong !) and the question is to show that the long term behaviour as x->infinitty is that x approaches (1/2)e^(-x)
That would make sense. But I'm not sure what they mean by show. Casually you would just pick the dominant term in the numerator (e^x) (dominant meaning the ratio of any other term in the numerator and that one goes to zero) and the dominant term in the denominator (2e^(2x) and divide them. If they want you be more formal they might want you to show limit f(x)/g(x) goes to 1, where f(x) is your original expression and g(x)=(1/2)e^(-x).
Thank you very much.
Dick, Your final remark about the more formal approach requires me to know the answer, ie g(x) already, which was obtained by the "casual" approach. So how do you find g(x) more formally than using the casual approach ? Thanks a lot !
I don't think there is any 'formal' way to find g(x). You just throw out parts of the function that are less important. The only question was do you have to PROVE that what you've kept of the function is the important part? In that case showing limit f(x)/g(x)->1 would be one way.
Got it. Thanks again.
  • · Replies 20 ·
  • · Replies 105 ·
