Example of a differentiable structure on R
The discussion revolves around the differentiable structure on the real line R generated by the map x^3. Participants explore the implications of this map for the smoothness and compatibility of charts within the context of differentiable manifolds. The conversation includes technical explanations and clarifications regarding the definitions of charts, atlases, and smooth structures.
  • One participant questions the smoothness of the inverse map x^{1/3} at x=0, suggesting that different charts may be needed at this point.
  • Another participant clarifies that x^{1/3} is continuous at x=0 but its derivative is not defined there, indicating that the smooth structure generated by x^3 differs from the standard smooth structure on R.
  • A participant expresses confusion about what it means for the map x^3 to "generate" a differentiable structure, noting that it seems to act like a chart but does not satisfy the smooth homeomorphism requirement.
  • One participant provides a detailed explanation of smooth atlases and structures, emphasizing the need for smoothly compatible charts and the process of determining whether two atlases generate the same smooth structure.
  • Another participant reflects on their understanding of charts and atlases, noting that only smoothly compatible charts are required and suggesting that translations of the original mapping might also be included in the atlas.
  • Further discussion includes the idea that differentiability is context-dependent and that the smoothness of charts is not universally applicable across all topological manifolds.
  • One participant proposes that the atlas generated by x^3 could include additional charts, such as translations, and discusses the conditions for smooth compatibility between these charts.
  • There is a correction regarding the smoothness checks for the mappings, with a participant pointing out potential errors in the verification process of compatibility.
Participants express differing views on the implications of the map x^3 for the differentiable structure on R, particularly regarding the smoothness of the inverse map and the nature of chart compatibility. The discussion remains unresolved with multiple competing perspectives on the topic.
Participants highlight limitations in their understanding of smoothness and compatibility, as well as the specific conditions under which differentiability is defined. There are unresolved mathematical steps regarding the smoothness of certain mappings and their implications for the differentiable structure.
mordechai9
Consider the manifold of the real-line R with a differentiable structure generated by the map x^3 : M \rightarrow \mathbb{R}. This example is given in a textbook I'm looking at, but I don't really understand how this can work. The inverse map is clearly not smooth at x=0.
Do they mean that at points like x=0 you have to take different charts, centered at other points besides x^3=0 in the image or something?
(Edited to say smooth instead of continuous.)
Why do you think x^{1/3} not continuous at x=0? As x approaches from the right, x^{1/3} goes to 0, and as x approaches from the left, x^{1/3} goes to 0.
But maybe that was a typo and you meant that the derivative of x^{1/3} is not defined at x=0? That is true, and it is not a problem; it only means that the smooth structure x-->x^{1/3} on R is a different one from the smooth structure x-->x.
Ah yea, sorry, I meant to say *smooth*, not continuous.
Regarding your answer -- I don't understand, or maybe I am not understanding what it means for this map to "generate" the differentiable structure. As I understand it, this map x^3 will act just like a chart; so therefore it must be a smooth homeomorphism -- but then that is clearly not true, like we've discussed. What do you mean that the smooth structure is just different? Thanks--
Ok, say you have a topological manifold M. That is, a space locally homeomorphic to R^n, Hausdorff, 2nd countable and whatnot. Then a smooth atlas on that topological manifold is a choice of charts of M that are smoothly compatible: that is, charts such that the transition functions between those charts are diffeomorphisms (smooth with smooth inverse). Now a smooth structure on M is a maximal smooth atlas: that is, a smooth atlas A such that if you try to add any chart of M that is not already in A, then there will be some chart of A with which is will not be smoothly compatible.
And of course any smooth atlas for M is contained in a unique smooth structure: such add all the charts that are smoothly compatible with each other and with those of A. Thus, if an atlas A is contained in a smooth structure S, then A is said to generate S.
Note that to tell whether or not two smooth atlases A, A' generate the same smooth structure, we just have to check wheter or not all the charts of A are smoothly compatible with all the charts of A'.
So! What we have here is 2 atlases for the manifold M=R: A={f:R-->R: x-->x} and A'={g:R-->R:x-->x³}. In particular, they are both smooth atlases since the smooth compatibility conditions is trivially satisfied since both atlases are only made of one silly chart! To check wheter or not A and A' determine the smooth structure, we then have to verify that the transition functions g o f^{-1}(x) = x³ and f o g^{-1}(x)=x^{1/3} are smooth. The first is, but the second is not, as you noted.
OK, thank you for that review. For my own edification I will make a few comments or remarks now. I thought that a chart just had to be smooth -- I didn't realize that we actually only require the weaker condition that the chart only needs to be smoothly compatible.
Also, I suspected that the atlas generated by the map x^3 would have more charts than just x^3 in the atlas. For example, take a new map x': M \rightarrow \mathbb{R} which is just a translation of the old mapping, defined by x' = x^3 + p, where p \in \mathbb{R}. It looks like this chart is smoothly compatible with x^-1, since x^{-1} \circ x' = (x^3 + p)^{1/3} is differentiable everywhere. Also the other direction x'^{-1} \circ x = (x^3 - p)^{1/3} looks to be differentiable at all points in M.
I thought that we would need to check the smoothness of all these maps generated by x but I guess that's not necessary, you just only allow the charts in the atlas to be exactly the ones that are smoothly compatible with the original chart.
Actually, it does not make sense in a general topological manifold M to speak of the smoothness of a chart U-->R^n. Differentiability is something that makes sense for maps between normed vector spaces.
Call \phi:\mathbb{R}\rightarrow\mathbb{R}:x\mapsto x^3 and \psi:\mathbb{R}\rightarrow\mathbb{R}:x\mapsto x^3+p. To check that these charts are smoothly compatible, you must check that \psi\circ\phi^{-1}:x\mapsto x+p and \phi\circ\psi^{-1}:x\mapsto x-p are smooth. Note that that you wrote the opposite: you checked that \psi^{-1}\circ\phi and \phi^{-1}\circ\psi are smooth (which they are not by the way; there is a problem at x=±p^{1/3}.)
  • · Replies 36 ·
  • · Replies 20 ·
  • · Replies 0 ·
  • · Replies 21 ·
