Exit velocity of gas through two orifices
  • Thread starter Thread starter Albo
    Flow Gas Tube
The discussion revolves around the flow of gas through two orifices of different diameters located in the same cross section of a tube. Participants explore how the gas distribution and velocity are affected by the orifice sizes, with a focus on applications in flow straightening elements and the implications for laminar flow.
  • Some participants propose that the amount of gas flowing through each orifice is proportional to their cross-sectional area, while the gas velocity through the orifices is inversely proportional to the area.
  • One participant suggests that the head loss through each orifice would be the same since they are in parallel, but questions arise about whether this assumption holds true given the size-dependent pressure drop in the orifices.
  • Another participant mentions that the distribution of flow depends on the relative locations of the orifices and the tube wall, indicating the complexity of the fluid mechanics involved.
  • Some participants discuss the need for computational fluid dynamics (CFD) simulations to obtain accurate results, while others express a desire to explore the problem experimentally.
  • There is a discussion about the implications of tube length on flow distribution, with one participant questioning whether equal flow division is reasonable when considering frictional losses in longer tubes.
  • One participant presents a derivation involving head loss and continuity equations, but acknowledges that their assumptions may not fully account for pressure drops and other factors.
Participants express differing views on the assumptions regarding flow distribution and head loss, indicating that multiple competing perspectives remain. The discussion does not reach a consensus on the effects of orifice size and placement on flow characteristics.
Limitations include the dependence on assumptions about flow properties, the neglect of compressibility effects, and the complexity introduced by the orifice placement and tube length. The discussion highlights the need for further exploration to clarify these factors.
Albo
If a gas flowing through a tube would meet two orifices with different diameters in the same cross section, how much of the gas would flow through each orifice and what would the gas velocity be in dependence of orifice diameter?
Welcome to PF.
Do you mean 2 orifices in a flat cylindrical plate sealing the end of a tube? Can you show us a sketch? (use "Attach files" below the Edit window to upload a PDF or JPEG image)
Also, is this question for schoolwork? What do you think will happen to the flow through the 2 orifices?
Hi! Thank you so much for the quick answer.
No the question isnt school related, i'm trying to develop a flow straightener element and trying to figure out the effect of combining different orifice sizes to the velocity profile and therefore the laminarity (if thats a word :D).
Yes you understood my question correctly! I'm thinking that the amount of gas flowing through each orifice is proportional to their cross sectional area. If i understand correctly tho the as the gas velocity through the orifice is antiproportional to the area the gas velocity through both orifices would be the same which suprised me. Just wanted to double check that i didnt mess something up
Yes you understood my question correctly! I'm thinking that the amount of gas flowing through each orifice is proportional to their cross sectional area. If i understand correctly tho the as the gas velocity through the orifice is antiproportional to the area the gas velocity through both orifices would be the same which suprised me. Just wanted to double check that i didnt mess something upView attachment 333791
The head loss through each orifice would be the same as the other (as the orifices are in parallel). What system of equations did you solve to arrive at your conclusion?
EDIT: I assume you use:
$$ h_{l_1} = h_{l_2} $$
$$ h_l \approx \frac{ (V_o - V_u)^2}{2g} $$
Where ##V_o## is the orifice velocity, and ##V_u## is the velocity of the flow upstream.
$$ \frac{ (V_{o_1} - V_u)^2}{2g} =\frac{ (V_{o_2} - V_u)^2}{2g} $$
$$ \implies V_{o_1} = V_{o_2} $$
I wouldn't think it to be extremely precise, but perhaps its fine.
The distribution of the flow between the two orifices depends on the locations of the two orifices relative to one another and relative to the tube wall. This is a pretty complicated fluid mechanics problem, even for laminar flow.
How do you know that? Sorry if the answer to this question is straight forward but it isnt to me. Ofc the pressure at the outlet is the same for both orifices but wouldnt the pressure drop in the center of the orifice be different because its size dependent? Maybe im just confused.
Regarding your derivation: no i went much simpler and just assumed the orifices to be tubes (which they obviously are) with crossection A_1 and A_2. Then i assumed the volume flow through each tube is proportional to the area
q1 = Q * A_1 / (A_1+A_2)
q2 = Q * A_2 / (A_1+A_2)
The velocity through a tube is then just the volume flow divided by the cross section
v1 = q1/A_1
v2 = q2/A_2
This would always lead to
--> v1 = v2
Of course these assumptions are not true since im not accounting for pressure drop and since (like Chestermiller) said it depents strongly on orifice placement and relative position to the tube and so on... Im just looking for some qualitative feeling for it
Yes that is true. For a real answer i would probably need some CFD simulations. But i dont want to go too much into detail with it and just find out experimentally if it works the way i want it too.
Basically my question originates from the problem: Which leads to a flow which is 'longer' 'stable' (laminar for a larger distance)?
(simplified ofc in top down view)
Version 1
or
Version 2
The approximate head loss for flow through an orifice? I looked it up in my textbook.
Or that the flows divide by head loss all other things equal?
I think it could ( and perhaps is by @Chestermiller ) be argued that it's an oversimplification and that ##V_{o_1} \neq V_{o_2}##.
Yeah this one. Which textbook are you referring to? id like to read it myself :)
It's an "oldish" textbook now. Engineering Fluid Mechanics; Crowe, Elger, Williams, Roberson; 9th edition.
Albo said:
Yeah this one.
Imagine you have a large pipe that splits into two of equal diameter. One of those pipes is 100 m long and the other is 1000 m long, they both eject to atmosphere without changing elevation. Your result says the flow divides equally (same areas), does that result seem reasonable to you?
Interesting question and maybe this is where im confused. The pressure difference would be the same but the friction in the tube would slow down the gas in the longer tube more leading to a lower mass output, correct?
Correct, there is more frictional work done on the flow in the longer tube. That equates to waste heat generation, which either warms the flow, or escapes via heat transfer to the environment. That extra heat is taken from the kinetic energy of the flows.
If you assume uniform flow properties over the cross section, you can write Work-Energy between the junction and each of the end points, the result is:
$$ \overbrace{\frac{V_1^2}{2g}}^{\text{kinetic head branch 1}} + \overbrace{\sum_{j \to 1} h_l}^{ \text{waste heat branch 1} }= \overbrace{\frac{V_2^2}{2g}}^{\text{kinetic head branch 2}} + \overbrace{\sum_{j \to 2} h_l}^{ \text{waste heat branch 2} } $$
The head loss in a branch can be found via Darcy-Weisbach:
$$ h_l = \frac{f L}{D} \frac{V^2}{2g} $$
Then you would use continuity ( incompressible flow ) to solve for the velocities (assuming the flow is slow enough to neglect effects compressibility - since you are considering "air" )
It should go without saying that there are obviously more refined flow models, but the idea should be fundamental.
  • · Replies 45 ·
