Why Does (\partial_{\mu}\phi)^2 Equal (\partial_{\mu}\phi)(\partial^{\mu}\phi)?
The equation (\partial_{\mu}\phi)^2 = (\partial_{\mu}\phi)(\partial^{\mu}\phi) is explained through the Einstein summation convention, where repeated indices imply summation. The right-hand side represents the sum over all dimensions, while the left-hand side assumes a scalar context where the index is summed with a metric tensor to raise one index. This notation can be confusing, as the left-hand side is less commonly used compared to the standard Einstein convention. The term \partial_\mu \phi is identified as a covariant first rank tensor, denoted as S_\mu, and its square S^2 = S_\mu S^\mu illustrates the summation principle. Understanding this shorthand is crucial for clarity in tensor notation.
noahcharris
I just came across this in a textbook: ## (\partial_{\mu}\phi)^2 = (\partial_{\mu}\phi)(\partial^{\mu}\phi) ##
Can someone explain why this makes sense? Thanks.
Mathematics news on Phys.org
The right-hand side is a short-hand way of writing
$$\sum_{\mu=0}^d (\partial_{\mu}\phi)(\partial^{\mu}\phi).$$
More generally, this shorthand is called the Einstein summation convention, commonly used whenever vectors and tensors appear, where a sum on a repeated index is assumed from the context of the expression. The left-hand side is a further shorthand, where if the quantity is supposed to be a scalar from the context, then it is assumed that the index is summed over with an appropriate metric tensor to raise one of the indices in the square. This is a shorthand that is more likely to be confusing and is used much less frequently than the Einstein summation convention itself.
Likes noahcharris
As you should know, ## \partial_\mu \phi## is a covariant first rank tensor, so you may name it ##S_\mu##. Now considering ##S^2\equiv S_\mu S^\mu##, will give you what you want.
Likes noahcharris
Specifically, that is the Einstein summation convention for tensors, a notational convention: The same index, both as a subscript and a superscript is interpreted as a summation index.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 0 ·
  • · Replies 17 ·
