Expanding the Fraction 1/x(x+1)^2: A Quick Guide for Scientists
  • Context: MHB
  • Thread starter Thread starter karush
The discussion centers on the expansion of the fraction $\frac{1}{x(x+1)^2}$ using partial fraction decomposition. Participants explore different methods and approaches to achieve this expansion, touching on both theoretical and practical aspects of the technique.
  • Homework-related
  • One participant presents an expansion of the fraction as $\frac{-1}{x+1}-\frac{1}{(x+1)^2}+\frac{1}{x}$, expressing frustration over the process.
  • Another participant details the use of partial fraction decomposition, deriving coefficients A, B, and C through a system of equations, ultimately providing the expansion as $\frac{1}{x}-\frac{1}{x+1}-\frac{1}{(x+1)^2}$.
  • A participant questions the approach to partial fractions, suggesting that their method is easier and faster by selecting specific values for x to find coefficients.
  • Some participants discuss whether the term "expand this fraction" was understood in the context of partial fractions, indicating a lack of formal instruction on the topic.
  • One participant shares a recollection of learning various forms for partial fraction decomposition in earlier courses, outlining different cases for linear and quadratic factors.
  • Another participant expresses surprise that partial fraction decomposition was covered in precalculus, noting it was mentioned as a useful skill for calculus.
  • There is a discussion about the independence of equations derived from the expansion, with one participant explaining why certain combinations of terms lead to independent equations.
  • A participant expresses gratitude for the explanation provided, indicating a reliance on calculator functions without understanding the derivation.
Participants exhibit a mix of agreement and disagreement regarding the methods and understanding of partial fraction decomposition. While some find the presented methods effective, others question the clarity of the instructions and the foundational knowledge assumed.
Some participants indicate that the topic of partial fraction decomposition was not covered in their classes, leading to confusion about the expectations for the problem. Additionally, there are references to various cases of polynomial decomposition that may not have been fully explored in the discussion.
This discussion may be useful for students learning about partial fraction decomposition, educators seeking to understand student perspectives on the topic, and individuals interested in mathematical reasoning related to polynomial expansions.
karush
MHB
Expand
$\frac{1}{x\left(x+1\right)^2}
=\frac{-1}{x+1}-\frac{1}{\left(x+1\right)^2}+\frac{1}{x}$
I tried for an hour but no
Using partial fraction decomposition, we may write:
$$\frac{1}{x(x+1)^2}=\frac{A}{x}+\frac{B}{x+1}+\frac{C}{(x+1)^2}$$
Multiply through by $x(x+1)^2$ to get:
$$1=A(x+1)^2+Bx(x+1)+Cx=A(x^2+2x+1)+B(x^2+x)+Cx=(A+B)x^2+(2A+B+C)x+A$$
Equating coefficients, we obtain the system:
$$A+B=0$$
$$2A+B+C=0$$
$$A=1\implies B=-1\implies C=-1$$
Hence:
$$\frac{1}{x(x+1)^2}=\frac{1}{x}+\frac{-1}{x+1}+\frac{-1}{(x+1)^2}=\frac{1}{x}-\frac{1}{x+1}-\frac{1}{(x+1)^2}$$
Has anyone else seen this approach to Partial Fractions?
[tex]\frac{1}{x(x+1)^2}\;=\;\frac{A}{x}+\frac{B}{x+1}+\frac{C}{(x+1)^2}[/tex]
Multiply through by the LCD: .[tex]1 \;=\;A(x+1)^2+Bx(x+1)+Cx[/tex]Now select values of [tex]x[/tex]:
. . [tex]\text{Let }x = -1:\;1 \:=\:A(0) + B(0) + C(-1) \quad\Rightarrow\quad \boxed{C = -1}[/tex]
. . [tex]\text{Let }x = 0:\;\;1 \:=\:A(1) + B(0) + C(0) \quad\Rightarrow\quad \boxed{A = 1}[/tex]
. . [tex]\text{Let }x = 1:\;\;1 \:=\:A(4) +B(2) + C(1) \quad\Rightarrow\quad 1\:=\: (1)4 + 2B +(-1)1 \quad\Rightarrow\quad \boxed{B = -1}[/tex]See? . Isn't this easier and faster?
Why is the demonator expansion of
$$x\left(x+1 \right)^2 $$
$$x, \ \ x+1, \ \ \left(x+1\right)^2 $$
When you were given this problem, did you understand what "expand this fraction" meant? That is, had you been given instruction is "partial fractions"?
this was never covered in class i just have textbook examples and forums
When I was a student in Precalculus/Calc II, we were given various forms for partial fraction decomposition without proof:
Suppose $P(x)$ is a polynomial whose degree is less than that of $Q(x)$.
Case I: Nonrepeated Linear Factors
$$\frac{P(x)}{Q(x)}=\frac{P(x)}{\prod\limits_{i=1}^{n}(a_ix+b_i)}=\sum_{i=1}^{n}\left(\frac{C_i}{a_ix+b_i}\right)$$
Case II: Repeated Linear Factors
$$\frac{P(x)}{Q(x)}=\frac{P(x)}{(ax+b)^n}=\sum_{i=1}^{n}\left(\frac{C_i}{(ax+b)^i}\right)$$
Combining the Cases: When the denominator $Q(x)$ contains distinct as well as repeated linear factors, then we combine the two above cases.
Case III: Nonrepeated Irreducible Quadratic Factors
$$\frac{P(x)}{Q(x)}=\frac{P(x)}{\prod\limits_{i=1}^{n}(a_ix^2+b_ix+c_i)}=\sum_{i=1}^{n}\left(\frac{C_ix+D_i}{a_ix^2+b_ix+c_i}\right)$$
Case IV: Repeated Irreducible Quadratic Factors
$$\frac{P(x)}{Q(x)}=\frac{P(x)}{(ax^2+bx+c)^n}=\sum_{i=1}^{n}\left(\frac{C_ix+D_i}{(ax^2+bx+c)^i}\right)$$
All of the above 4 cases may be combined.
you did this in precalculus?
Yes, we just didn't apply it to integration then...we were told it would be used later on in calculus, but that it was in general a good skill to learn. :)
The reason that expansion works is that, for any A, B, C,
[tex]\frac{A}{x}+ \frac{B}{x+ 1}+ \frac{C}{(x+ 1)^2}= \frac{A(x+ 1)^2}{x(x+ 1)^2}+ \frac{Bx(x+1)}{x(x+ 1)^2}+ \frac{Cx}{x(x+ 1)^2}[/tex]
[tex]= \frac{Ax^2+ 2Ax+ A}{x(x+1)^2}+ \frac{Bx^2+ Bx}{x(x+1)^2}+ \frac{Cx}{x(x+ 1)^2}[/tex]
[tex]= \frac{(A+ B)x^2+ (2A+ B+ C)x+ A}{x(x+ 1)^2}[/tex]
And the three equations, A+ B= p, 2A+ B+ C= q, A= r, are independent so can be solved for A, B, and C for any p, q, and r.
Notice what happens if we try just [tex]\frac{A}{x}+ \frac{B}{(x+ 1)^2}[/tex]. We get [tex]\frac{Ax^2+ 2Ax+ A+ Bx}{x(x+ 1)^2}= \frac{Ax^2+ (2A+ B)x+ A}{x(x+ 1)^2}[/tex] and the equations A= p, 2A+ B= q, A= r are not independent.
thank you, that helped a lot
i normally just use the expand() on the TI not knowing how it was derived.😎
