Expanding Trig Functions: [(Cos^3)x][(Sin^4)x] in Terms of cos(x) and Its Powers
  • Thread starter Thread starter H0T_S0UP
The discussion focuses on expressing the product of cos^3(x) and sin^4(x) in terms of cos(x) and its powers. The initial attempt involved breaking down the functions but led to confusion when trying to reintroduce sin(x) after working with cos(x). A key realization was that cos^3(x) is already in the desired form, and the simplification of sin^4(x) should stop at a certain point. The correct approach is to multiply the simplified expression for sin^4(x) by cos^3(x) to achieve the final result. This led to the correct expression: cos^3 - 2cos^5 + cos^7.
H0T_S0UP
Express [(Cos^3)x][(Sin^4)x] in terms of cos(x) and its powers:
All I used was Sin^2+Cos^2=1 but apparently it didn't work! I probably should have used more identities but I don't know.
I broke the equation into two sections, the [(Cos^3)x] and then [(Sin^4)x] multiplied them together
For [(Cos^3)x]
cos(x)(1-sin^2 (x))
cos(x)-cos(x)(sin^2 (x))
cos(x)-cos(x)[1-cos^2 (x)]
cos^3 (x)
For [(Sin^4)x]
(1-cos^2 (x))(1-cos^2 (x))
1-(cos^2 (x)) - (cos^2 (x)) + (cos^4 (x))
1 - (2cos^2 (x)) + {[1-sin^2 (x)][1-sin^2 (x)]}
1 - (2cos^2 (x)) + 1-(2sin^2 (x)) + (sin^4 (x))
{(sin^4 (x)) - 2(cos^2 (x)) - 2(sin^2 (x)) +2}
And I stop here because the same pattern could go on forever and ever!
Where did I go wrong and can someone please show me the work the review sheet does not have it obviously.
If I'm reading the problem right, you need to reduce the product of cos^3 * sin^4 into just powers of cos? right? Well you are making the problem too hard by trying to do anything with cos^3. It is already a power of cos, so you don't need to do anything with it. This is why you are coming around full circle back to cos^3 on that part. In your solution for sin^4, you have a line that is all cos. Stop there. Don't try to put sin back in after that. All that's left is to mutiply that through by cos^3.
Oh wow thanks I can't believe the mistake was that simple. If I did multiply 1-(cos^2 (x)) - (cos^2 (x)) + (cos^4 (x)) by cos^3 (x) I would have gotten:
cos^3 - 2cos^5 + cos^7 which was the correct answer.
Thanks.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
Since ##px^9+q## is the factor, then ##x^9=\frac{-q}{p}## will be one of the roots. Let ##f(x)=27x^{18}+bx^9+70##, then: $$27\left(\frac{-q}{p}\right)^2+b\left(\frac{-q}{p}\right)+70=0$$ $$b=27 \frac{q}{p}+70 \frac{p}{q}$$ $$b=\frac{27q^2+70p^2}{pq}$$ From this expression, it looks like there is no greatest value of ##b## because increasing the value of ##p## and ##q## will also increase the value of ##b##. How to find the greatest value of ##b##? Thanks
