Expanding universe needs a big bang?
101 replies · 11K views
Sure. I just suspect the question in OP's mind is more about what made the chicken cross the road, and less about what tried to prevent it. :wink:
Astronomy news on Phys.org
PeterDonis said:
The gravitational effect of radiation and ordinary/dark matter makes a contribution to the rate of expansion we actually observe. The fact that the contribution is of the opposite sign to the contribution of dark energy does not mean it isn't there or doesn't count.
right, that affects rate. right, both signs matter (to the topic of rate), but not (both signs matter) to the topic of why universe is expanding. Let me know if I'm wrong.
PeterDonis said:
Note, btw, that DE acts to accelerate the expansion, but inertia does not; inertia alone would just keep the expansion rate the same. So the contribution of ordinary matter/dark matter and radiation is not "opposite" to the contribution of inertia.
right, understood.
actually that point is related to what i was going on about.
in reverse: 'inertia's contribution is not 'opposite' to the contribution of dark matter etc'. But DE's is.
It was in that sense that i felt DE was what was important, as far as explaining the expanding universe.
thank you for all your help with this.
I don't think it's a matter of being "right" or "wrong". It's just your personal judgment about what answer satisfies you for what question.
Well, isn't it more objective than that? To explain why something expands, doesn't include why something contracts.
Explaining why the rate is what it is, would include both.
No?
Bandersnatch said:
But remember that expansion of the universe is not a nebulous term, but one with a specific meaning - it's the growth of large-scale distances. So if you ask what causes expansion, then you're asking what causes the distances to grow. The answer must then be the recession velocity (by definition; it's what velocity means), which in turn has contributions from both DE and the initial impulse.
right, i will remember that.
thank you again for your clarifications,
I would say that decelerating expansion is not the same thing as contraction. But now we're just having different preferences for how we use words. To you, "explaining expansion" only includes, apparently, explaining why expansion either continues at the same rate, or accelerates. To me, it includes everything that's necessary to explain why the observed rate of expansion is what it is. We agree on the physics; we're just choosing different ordinary language to describe it.
Note, again, a matter dominated universe with no dark energy will expand forever if there is not too much mass. It is just that the power law followed by the scale factor will have a positive exponent less than 1.
Btw, it's worth noting in this connection that the description of the expansion as "accelerating" or "continuing at the same rate" or "decelerating", that we have been using in this thread, depends on a particular definition of what the "expansion rate" is: that it is the (normalized) second time derivative of the scale factor, ##\ddot{a} / a##. But we don't directly observe this. What we directly observe is the Hubble constant ##H## and its rate of change ##\dot{H}##. But ##H## is not increasing with time! What we have been calling "accelerated expansion" does not mean ##H## increases; it just means ##H## is decreasing asymptotically towards some positive constant (related to the cosmological constant) instead of towards zero.
So if we think of things in terms of ##H## as the "rate of expansion", then this rate is always decreasing, and dark energy, inertia, and ordinary/dark matter and radiation are just factors that make different contributions to the rate at which ##H## is decreasing. On this view it's not clear why any of those factors could be excluded in "explaining expansion".
Hi, do you mean that the (constant) velocities are such that we've past the point that gravity could reverse the direction?
The density of ordinary matter and dark matter in our universe (radiation is negligible now) combined is much less than the critical density, so the ordinary and dark matter in our universe is much less than the amount that would be needed to make it possible for our universe's expansion to stop and reverse direction, even if there were no dark energy.
Right, I get that. But I only get that -- under the idea that they are also moving at some (minimum) velocity.
That is, suppose we stopped their relative motions right now and then let go of them.
Would expansion commence? Apparently it couldn't, because PAllen said no DE (which is acceleration), and for motion to commence is motion to accelerate.
Or is my hypothetical situation missing something?
Oh hang on here, I shouldn't specify the need of a minimum velocity because the 'minimum' would depend on the ratio of separation to mass, right? So, I can, in a sense, dip below the minimum, by increasing the separation. So that, in effect, the result (expansion) is necessary given the ratio mass to spacing, alone. Is that right?
Meaning, if there were no dark energy, just ordinary/dark matter and radiation? Then an initial state where relative motion was zero would lead to contraction. (The initial state would basically be a closed universe at the instant of maximum expansion.) This is one way of seeing why inertia, as I have been calling it, is among the factors that are needed to explain why the expansion rate now is what it is.
Deceleration is also "motion commencing", and, as above, that is what would happen if you had a universe in a state of zero relative motion at some instant, containing only ordinary/dark matter and radiation.
It's the ratio of actual density to critical density (assuming we're only considering situations with zero dark energy/cosmological constant), where the critical density depends on the Hubble constant. That dependence on the Hubble constant is where the "spacing" comes in, since the Hubble constant ##H = \dot{a} / a##, so it depends on both the "speed" and the "spacing".
Okay, got it.
PeterDonis said:
Deceleration is also "motion commencing".
Ah, very true!
Deceleration would happen given some instant of zero relative motion? First quote says contraction happens.
So, are you saying that we are to think of that contraction as deceleration?
Vaclav Vavrycuk said:
and speculative
As been told to you in your thread, it is not.
Not quite. "Deceleration" as I was using the term means ##\ddot{a} / a < 0##. "Contraction" means ##\dot{a} / a < 0##.
In the case of a closed universe with zero cosmological constant at the instant of maximum expansion, the first (deceleration) is true (since it's always true in a closed universe with zero cosmological constant) and the second (contraction) starts being true an instant later.
In the case we've been discussing for much of this thread, a universe that is expanding but with zero cosmological constant, the first (deceleration) is true, but the second (contraction) is not.
So, given no relative motion at an instant, and given no DE (as PAllen specified), each body would decelerate between the time of that instant and time 2? And just to check, the separation between two neighboring bodies is increasing or decreasing?
Which case are you talking about? The quote you gave from me is about a universe that is expanding but with zero cosmological constant. Since that universe is expanding, "given no relative motion at an instant" is not true for that universe.
If you are talking about the other case (a closed universe with zero cosmological constant at the instant of maximum expansion), then "no relative motion" is true at that instant. For that universe, "deceleration" (##\ddot{a} / a < 0##) is always true, not just at that instant, as I said before.
It was stated by PAllen that the universe would expand regardless of DE. That's the universe I am talking about. I found this 'necessity of expansion' interesting. I wanted to see whether the existing velocities have anything to do with this necessity being one. So, I gave a hypothetical -- let's say we go out and find two neighboring objects whose separation is expanding, and we stop their relative motion with force. Then we let them be. My question is, what will happen to that separation after the instant that we let them be? Will it increase again? If my hypothetical is not allowed, why is that?
Comeback City said:
I'm assuming GR rules this possibility out anyways, yes? (regardless of its likelihood, that is)
That's right. GR breaks down everywhere at t=0, not at a single location. In other words, the big bang singularity occurs everywhere in GR.
Please note, I said assuming homogeneity and isotropy (and no DE). Stopping two objects in isolation violates these assumptions. It was also clarified in discussion with Peter that you could run a Big Bang expansion forever backwards (contraction from the infinite past) and that the math of GR doesn’t care which interpretation of the solution you adopt. Physical plausibility, though, picks out the expansion as the physical time direction.
As Peter has already explained, any homogenous, isotropic situation with a moment of no expansion must have expansion from Big Bang before this, followed by Big Crunch after.
I believe he meant that our universe, with the density of matter and radiation that it has, would keep expanding even without DE, because the combination of inertia and the effect of matter/radiation would not be sufficient to cause the expansion to ever stop; the density of matter and radiation is less than the critical density, so the universe would keep expanding forever even without DE.
Then the objects will no longer be comoving, so their motion will in general not be the same as the motion we describe as the "expansion of the universe", which is defined with respect to comoving objects, and won't tell you much about that expansion.
PeterDonis, PAllan
got it, thank you for your clarifications,
Ken G said:
So it is for dark energy and the Big Bang-- we think of the Big Bang as being akin to an initial condition (that is not explained by any physics at present), and then the physics kicks in and tells us what happened next. So which is the "cause" of the expansion we now see? Which is the cause of a home run, the batter who hit it or the pitcher who pitched it? Both are, together.
Right, i read all you said in that post and agree. Thanks for all your posts Ken.
I was thinking of expansion in a certain way, not as 'what is in fact happening', but as a possible circumstance between two material points (regardless that it's happening).
And I was focused on a certain 'mechanism' that would give rise to expanding, because I felt it generated a more authentic kind of expanding. That mechanism is DE.
Thanks again,
And if I'm not mistaken, that is the problem with the "bang"...if it happened "everywhere" how could there not be a center? I've been reading a lot of articles that are seriously questioning the "big bang theory"...
You have that backwards. "If it happened everywhere how COULD there be a center" is the right question and of course that makes sense since there WAS no center.
The big bang simply describes the fact that our current model, the Lambda-Cold-Dark-Matter (LCDM) model, suffers from infinities when we run time back to a certain point, which we call t=0. And that after this point in time it rapidly expands, going from a very hot, very dense state to a much less dense and cooler state. Crucially, the model describes and predicts a great many things in cosmology with very good accuracy, such as the distribution of matter, the ratio of different elements, the CMB, among others. The LCDM model is in no danger of being replaced any time soon. Especially since we keep finding more and more evidence supporting it.
I'm not sure which articles you are reading, but unless they are reputable scientific papers then they simply don't matter. You can find thousands of articles written by news sites, amateur scientists, and others that say all sorts of things which seemingly goes against the standard view of science. This is because they aren't professional scientists and don't always know which ideas are well accepted and which ideas are either fringe or obsolete.
Also, bear in mind that one should determine the "Big Bang theory" from a more colloquial meaning of the Big Bang as a singular event happening everywhere. The theory is built from two basic postulates, general relativity and the cosmological principle. The latter says that the universe is more or less the same everywhere on large scales at a given age. So since general relativity is a dynamical theory, you can take the situation that we currently observe and check that the dynamical story works out. Then you can extrapolate it back before we can see (before about 400,000 years old when the opacity became to great to see though), and check that that story also works out. With some key caveats (dark matter, dark energy, inflation) it does.
So all that is the "Big Bang theory." None of it refers to any creation event, or anything happening everywhere, because we're not sure how far back we can get away with our two postulates. We literally don't know if general relativity still works all the way back to the beginning, if the cosmological principle still applies, or if we have the idea right about inflation (for which there really is no confirmed theory at all). So astronomers apply "the Big Bang theory" essentially daily, without ever even mentioning how far back they imagine they can extrapolate it. For that reason, it actually isn't a theory about the beginning of the universe, though it is often mistaken for that.
By contrast, the Big Bang "event" is intended to be a creation event, but there's no scientific theory for it. It's more like a pop sci picture of what might have happened, that we really have no way to test at present. Part of the problem is that the scientific theory that we actually do have predicts an early phase that is a thermodynamic equilibrium with only tiny variations, of which we can only see a tiny part because it is thought to have expanded so much as to dwarf what we can actually see. It's hard to imagine a physical system that is better at covering its tracks than that!
This was answered completely for you here:
https://www.physicsforums.com/threa...ue-then-how-can-there-not-be-a-center.962125/
Continuing to ask the same question is not going to change the answer. There was no center because there was no point (in space) where it began.
