Explanation of EM-fields using SR
  • Level: Graduate
  • Thread starter A.T.
    Explanation Sr
134 replies · 62K views · last reply
TrickyDicky said:
Universal, instead of bringing further confusion by questioning everyone's relativity knowledge thru your distorting misconceptions, why don't you tell us if you finally understood why in the presence of current length contraction in the wire's frame retains neutrality while in frames moving wrt the wire it doesn't.
I don't feel like turning a blind eye and start bookkeeping, in favor of observed facts and the standard theory. So, no I still don't know why there are two definitions of Length Contraction one for the current on-off, and other for the regular Lorentz transform of a current.
DaleSpam said:
So does that mean that you understand it now?
You haven't presented any logical argument yet, and I don't even know what do you want me to understand. But to me it seems that you don't want to apply the length contraction to the current, and at the same time you want to keep it under the domain of applicability of SR.
DaleSpam said:
I do apply the same definition to time dilation (I don't use relativistic mass at all).
Really! Then why do we have a net Time Dilation in Twin paradox and accelerators, and net length contraction in regular Lorentz transform, but not in the case of a current.
And please don't say, that since in a conductor, every charge wants to spread all over the volume and since the number of electrons are equal to the number of protons, so there is NO net charge due to Length contraction, because instead of contracting the inter gaps electrons tend to contract themselves at their previous spacing before the current. Because the ditto condition is always present for the regular Lorentz transform of a current.(i.e. a conductor...same volume...same no. of charges...no net charge...) where you changed the nature of Length contraction in order to get all the observed facts correct.
yuiop said:
In this pape http://www.chip-architect.com/physics/Magnetism_from_ElectroStatics_and_SR.pdf the charge density measured in the rest frame of a test charge moving at v relative to the wire, is given as:
##g_L = I v/c^2##
I might be wrong, but I suspect that is just for the special case when the drift velocity of the electrons ##(v_e)## is equal to the velocity of the test charge. If that is the case, then the more general expression should be:
##g_L = I (1/v_e)* (v^2/c^2)##
which reduces to the previous expression when ##v_e = v##
Expressed like this, it is easy to see that the slow drift velocity of the electrons (about 1mm per second) relative to the speed of light actually magnifies the effect and explains why the EM effect is one of the few relativistic effects readily observable at everyday velocities.
Any thoughts?
There is an inherent ##v_e## in the ##I## of your expression, which i think you missed. And I don't think a slow drift velocity magnifies relativistic effects, if it is anything then its the huge number of electrons, which is also inherently included in the ##I## and that is why you get the relativistic effects in everyday velocities.
TrickyDicky said:
Find the answer to what question exactly, can you phrase it in specific terms?
Sure. What we so far couldn't answer is the following basic question, as viewed from the rest frame of the electrical circuit: As the electrons are drifting in one direction, one would expect that their electric field parallel to the wire is reduced by γ2. In contrast, this doesn't happen for the electric field of the ions, nor for the electric field of the electrons in the battery. Why doesn't the wire suck in electrons from the power source (and from earth, if there is an Earth connection)?
[edit:] For a large power source I would expect the electron density in the wire to be increased by a factor γ. If you know the answer -as you seemed to suggest- please tell!
Because people are lazy in inventing new names. And because under the assumption of constant proper-length the two have the same result. But that assumption doesn't hold true for the electron distances.
Not every charge, just the free electrons, because they can change their proper distances. Contracted repulsive fields are still repulsive. So why should the electrons move closer together?
This is incomprehensible. And using bold font doesn't give it any more sense.
If you wonder why atoms in a lattice behave differently than free electrons when they start moving in some frame, then consider the different interaction in the two cases: Lennard-Jones potential between atoms can be attractive or repulsive. Coulomb forces between electrons are always repulsive.
The cations are fixed in the lattice, so they cannot change their proper distance. The electrons are free to move, so they can change their proper distance, while keeping the distance in the wire frame constant.
"Contracted repulsive fields are still repulsive", :rolleyes: , but a decreased repulsive field is basically an attraction compared to the situation when field is not decreased, and it essentially means less distance between electrons(attraction).
It should be, otherwise you would have to answer the question that I'm repeatedly asking.
And we are discussing just the relative motion under SR, and every thing about the internal structure is meaningless.
Wrong. As long as they repulse each other, they will distribute uniformly. Reducing the repulsive force doesn’t change that.
Wrong. We are discussing a specific physical situation.
Wrong. The fixed lattice structure is the reason why there is no symmetry between the cations and the electrons. So it is not meaningless, but actually the answer to your question.
I am wondering if you understand the arguments and explanations provided here: http://physics.weber.edu/schroeder/mrr/MRRtalk.html
I don't know why it seems that way to you. I thought I was very clear that length contraction does apply here:
https://www.physicsforums.com/showpost.php?p=4531669&postcount=94
and here:
https://www.physicsforums.com/showpost.php?p=4528325&postcount=22
We do have length contraction in the case of the current, as described above.
I have no idea about the way that you think that I "changed the nature of Length contraction". I don't know what you mean. Please be explicit. The different frames are related to each other via the Lorentz transform, the same as always and in all cases.
I decided to ascertain what part the drift velocity of the electrons play, by deriving the change in charge density from scratch.
Consider a wire at rest in a lab frame S with a current flowing in the x direction with drift velocity ##v_e##. The total charge density in this reference frame is
##p = (p_+) + (p_-)##
where ##p_+## is the charge density of the cations and ##p_-## is the charge density of the electrons. Since they have opposite signs and equal magnitude in this frame the total charge density in this frame is zero.
Now we transform to a new reference frame S' with velocity v relative to the lab frame and parallel to the wire, that is chosen to be not the same as the drift velocity ##v_e## so neither the electrons or the cations are at rest. The positive charge density in this reference frame increases by a factor of ##\gamma## due to the length contraction of the gaps between the positive charges. The transformation of the negative charge density is a little trickier because the electrons are moving in both S and S', but with the use of the relativistic velocity addition formula it can be ascertained that the gap increases by a factor of ##\sqrt{1-v^2}/(1-v_ev)## and the negative charge density decreases by the inverse of that factor, so the transformed total density is:
[tex]p' = (p_+)\gamma + (p_-)(1-v_e)\gamma[/tex]
[tex]p' = (p_+) \left(\frac{1 -(1-v_ev)}{\sqrt{1-v^2}}\right)[/tex]
[tex]p' = (p_+)\frac{v_ev}{\sqrt{1-v^2}}[/tex]
[tex]p' = - (p_-)v_ev\gamma[/tex]
The current in the lab frame is given by ##I = -(p_-)v_e## where the negative sign of the current follows the convention that current flows in the opposite direction to the negative charges. Inserting this value for I into the above equation yields:
[tex]p' = Iv\gamma[/tex]
So yes, as Dalespam said, the drift velocity of the electrons does not play a part and the correct charge density should contain the ##\gamma## factor.
yuiop said:
In their derivation they equate the magnetic force with the electric force, but they do not allow for the fact that the forces are measured in different reference frames. If we allow for this using the Lorentz transformation of transverse force, then I get ##F_{mag} = F_{elec}/\gamma## and this gives the same result as yours, ##Q_L=\gamma I v/c^2##. This of course implies that when the electric force is measured in the same reference frame as the magnetic force is measured in (two separate experiments alongside each other in the same lab) the equation for the electric force is gamma greater than the equation quoted in the paper. [..]
Yes indeed - well spotted! :smile:
However, it's unclear to me what you want to do with that... The only way forward that I see is to use the full equations - as de Vries also does in section 2 - and that looks pretty independent of the section with the error. Strangely enough, I don't see where he actually does the "full derivation" of the wrong "correct derivation" of section 1...
DaleSpam said:
The spacing of the electrons in the wire frame is determined by the observed fact that the wire is uncharged in the wire frame. This is a "boundary condition" that can be experimentally controlled.
This was actually the only explanation universal_101 needed all along and it basically makes the length contraction explanation moot, since it is actually the premise of the problem what forces the existence or not of neutrality in the different frames rather than length contraction by itself which is always present wrt the situation without current(see posts by samshorn about this in the parallel thread "are the transformations just observed...").
There seems to be a problem with this explanation and maybe it's what's been bothering him, this apparently innocent "boundary condition" is itself outside the scope of relativity by preferring one frame over the others wrt the effects of length contraction on neutrality(no effect on neutrality in the frame of the wire, that is cation's or Earth's
frame), but the fact that if we put the charge at rest with Earth's frame and move the wire instead will make lose the wire's neutrality too renders the condition seem totally ad hoc for the experiment and not relativistic at all.
I do agree with your characterization here. As you said, boundary conditions (in general) are outside the scope of the corresponding theory. And you are completely correct that asymmetric boundary conditions can disrupt the symmetry of the corresponding law of physics. You are completely correct in both of those points, and those points apply to all physics and not just relativity and not just this specific problem.
harrylin said:
To make it clearer, we can put a positively charged dog in rest with the wire, next to it. Now the cat, using the frame that is co-moving with the electrons as rest frame, has to explain the lack of net force on the dog despite the electric field. The cat can only explain this by the magnetic field of the moving ions and which must exactly compensate the electric field force.
This is a good question. The force acting on the dog should be neutral in both the rest frame of the dog and in the rest frame of the cat when the dog is moving relative to the cat. The analysis of the forces on the dog is a little more complicated than that of the cat so I will take Dalespam's advice and use the transformation of the four-current which can be expressed as:
##[\rho, \mathbf{I_x,I_y,I_z}]## using units where c=1.
I only want to analyse the case where the current and relative motion are always parallel to the wire which in turn remains parallel to the x axis. This simplifies things as ##\mathbf{I_y = I_z} = 0## so the four current can be abbreviated to ##[\rho, \mathbf{I}]## where I have defined ##\mathbf{I_x}## as ##\mathbf{I}##.
After performing a Lorentz boost with velocity v in the x direction:
##\rho' = \gamma_v(\rho - \mathbf{v I})##
##\mathbf{I'}= \gamma_v(-\mathbf{v}\rho +\mathbf{I})##
where ##\gamma_v## is the gamma factor for velocity v.
The Lorentz force acting on a test particle with charge q and velocity ##v_0## is defined as:
##\mathbf{F} = q(\mathbf{E} + \mathbf{v_0 \times B})##
In our simplified case this can be expressed in a non vector form as:
##F = q(E - v_0*B)##
(Note the change of sign when we use ordinary multiplication rather than the cross product.)
The electric and magnetic fields are defined in terms of various constants but we can conveniently use units such that ##E = \rho## and ##B = I## so that
##F = q(p - v_0*I)##.
In the rest frame of the dog, p=0 and ##v_0 = 0## so F =0.
In the general case, when carrying out the Lorentz transformation of the force, we should use the the transformed four velocity of ##v_0## or the relativistic velocity subtraction formula ##v_0' = (v_0 -v)/(1-v_0*v)## For the case of our positively charged dog which is at rest in S, the velocity of the dog in the rest frame of the cat (S') is ##v_0' = -v##.
The force acting on the dog in the cat's reference frame is:
##F' = q\rho' - qv_0'*I'##
##F' = q\rho' + qv*I'##
##F' = q(\gamma_v \rho - \gamma_v vI ) + qv(-\gamma_v v\rho +\gamma_v I)##
##F' = q\gamma_v(\rho - vI ) + q\gamma_v(- v^2\rho + vI)##
In the rest frame of the dog, the boundary conditions specified neutral charge density ##\rho =0## so the above reduces to:
##F' = q\gamma_v( - vI ) + q\gamma_v(v I)##
It can be seen that the electrostatic force on the dog is equal in magnitude and opposite in sign to the magnetic force on the dog as measured in the cat's rest frame, so there is still a total force of zero acting on the dog.
Noyhcat said:
I don't immediately get why the separation of the negatively charged particles doesn't contract from the man's reference frame, as they are moving relative to him, and therefore there would be a negative overall charge.
the negative particles do contract on the man's reference! It's just that they contract in a way that yields a zero electric field. The normal (rest) length between electrons is seen when in the moving observer- so we are always looking at a contracted density instead of a rest density when we observe.
