Undergrad Does a Polarizer Alter the Shape of Airy Disks in Optical Systems?
  • Thread starter Thread starter zincshow
    Effects Polarizer
Using a polarizer in front of a pinhole does not change the shape of an airy disk, as scalar diffraction is sufficient for a circular aperture. However, if a lens or focusing mirror is involved, the situation becomes more complex, and vector diffraction may alter the disk's shape, especially with a large numerical aperture. The discussion emphasizes the importance of the aperture type and the diffraction model used. Testing with a telescope and lunar filter could provide practical insights. Overall, the impact of a polarizer is contingent on the optical setup used.
zincshow
When an airy disk is formed, does using a polarizer in front of the pinhole change the shape of the disk?
No responses? Well I'm going to guess yes, and hourglass shaped. I might be able to test this for you with my telescope and a lunar filter...
It shouldn't make any difference. The far field diffraction pattern is just the Fourier transform of the aperture function, which in this case is a circular hole. Unless there's spatially varying polarisation in the incident radiation.
I'm not completely certain - I'd be interested in seeing your test, Russ.
Likes russ_watters
If it just a pinhole aperture, then no, scalar diffraction suffices. If you are using a lens (or focusing mirror), then yes, especially if the numerical aperture is large. Vector diffraction is considerably more complex than scalar diffraction, here's a few links:
https://www.osapublishing.org/josaa/abstract.cfm?URI=josaa-35-4-526
https://www.osapublishing.org/oe/abstract.cfm?uri=oe-12-12-2670
https://link.springer.com/content/pdf/10.1007/978-3-540-48471-4_6.pdf
https://spiral.imperial.ac.uk/bitst...a high numerical aperture focusing system.pdf
Likes Ibix and russ_watters
Thread 'What is the pressure of trapped air inside this tube?'
As you can see from the picture, i have an uneven U-shaped tube, sealed at the short end. I fill the tube with water and i seal it. So the short side is filled with water and the long side ends up containg water and trapped air. Now the tube is sealed on both sides and i turn it in such a way that the traped air moves at the short side. Are my claims about pressure in senarios A & B correct? What is the pressure for all points in senario C? (My question is basically coming from watching...
  • · Replies 19 ·
