Can Time Move Faster in Low Gravity Fields?
matdoya
I read on wikipedia that time goes slower in higher gravitational fields,
I also know that 'inside' a black hole time stands still.
(simplified, I know)
Does this mean that in places where the gravitational field is extremely low (far apart from galaxies and any other objects having mass) time goes infinitely fast?
So that if you would travel through such a place and the only gravity that wouldn't be neglectable is the one formed by your own mass and thus time proceeds extremely fast there?
just asking,
S.
The right to think about, I guess, it's that when you are here or here, you measure some time.
Every observer has some rules and some clocks to measure time.
Now suppose the twin paradox. The thing that actually happens is that their clocks will not measure the same amount of time, but time will pass as usual for both
The reason of this, it's the Lorentz Transformations, which are the ones you should use when relativistic effects are not negligible. this is, when speeds are not small when compared to the speed of light in vacuum, and when the distances traveled are long enough (I'm sorry but i do not know what long enough actually means in this context, but think about astronomical scale of course)
I thought that the 'solution' to the twin paradox was that first the traveling twin was traveling away from his Earth'sick brother with two different reference frames, but traveling back he travels in a third reference frame, one that is the inverse of his first one, eliminating any gain or lose in time made...
-> what is the difference between time passing by and measure it's progress?
-> the Lorenz transformations apply to the length of the moving object, not to the distance traveled
-> suppose for simplicity of argument that the speed indeed is nowhere near the speed of light, say the speed of sound or something...
S.
No, time would not be infinite. It would be "normal" time (no time dilation). Just let r go to infinity in the equation and you will see that time is not changed.
For some reason I always forget to check the equations :s.
It would have been cool though :)
S.
ps: in the formula on wikipedia
http://en.wikipedia.org/wiki/Gravitational_time_dilation#Outside_a_non-rotating_sphere
you can also set M to 0, same result (obviously)...
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
