Explosion-Generated Collapsing Vacuum Bubbles Reach 20K Kelvin - Comments
  • Context: Insights
  • Thread starter Thread starter klotza
    Bubbles Kelvin Vacuum
The discussion centers on the phenomenon of explosion-generated collapsing vacuum bubbles reaching temperatures of 20,000 Kelvin. Participants confirm that these bubbles are created using a stoichiometric mixture of hydrogen (H2) and oxygen (O2). Key points include the bubble's minimum pressure of 1 Pa and its maximum expansion temperature of 4,000 K. The conversation also touches on the relationship between cavitation, shock waves, and sonoluminescence, highlighting the damaging effects of bubble collapse in various applications.
  • Understanding of cavitation phenomena
  • Knowledge of thermodynamics, specifically the ideal gas law
  • Familiarity with sonoluminescence and its mechanisms
  • Basic chemistry of stoichiometric mixtures involving H2 and O2
  • Research the principles of cavitation and its applications in engineering
  • Explore the ideal gas law and its implications in high-temperature scenarios
  • Investigate sonoluminescence and its relation to shock waves
  • Study the effects of bubble dynamics on material integrity in high-pressure systems
Researchers in fluid dynamics, engineers working with cavitation in hydraulic systems, and physicists studying high-temperature phenomena will benefit from this discussion.
klotza
Insights Author
klotza submitted a new PF Insights post
Explosion-Generated Collapsing Vacuum Bubbles Reach 20,000 Kelvin
Continue reading the Original PF Insights Post.
Science news on Phys.org
Really interesting stuff! Love the animations!
"Mantis shrimp also produce sonoluminosity in cavitations " Google+
klotza said:
Yes they are. It leaves water vapour and some other stuff, and the water adsorbs into the fluid, just leaving very small amounts of other stuff.
Is there a non-paywalled version of this article?
I believe they stated that the minimum pressure of the bubble is 1 Pa with a temperature of 4,000 K at its maximum expansion. Is that correct.
The bubble then contracts, and at least initially should compress via the ideal gas law to a peak pressure and temperature? I think the graph shows that Rmin is about 0.2 of Rmax before rebounding slightly.
I thought in cavitation that the damaging effect comes from the bubble completely disappearing. As opposed to a flash, where the residual gas bubble mitigates the shock wave that is generated. We had a high pressure control valve where we used a small amount of N2 to keep prevent the complete collapse of the vapor phase. That worked well until the day we lost the nitrogen flow. Once the valve started cavitating, the valve was destroyed within the hour.
Did they relate the sonoluminecense to the sound shock wave that gets generated by the shock wave? Such as the shock wave comes first followed by the sonoluminecense? Or they initiate together?
  • · Replies 16 ·
  • · Replies 65 ·
10K
  • · Replies 220 ·
26K
  • · Replies 41 ·
