Exposure rate from thermal neutrons through water
The discussion focuses on calculating the exposure rate from thermal neutrons interacting with a 1 cm thick water target, specifically through the 1H(n,gamma)2H reaction. The neutron flux is given as 10^12 neutrons per cm² per second, and the atomic density of hydrogen in water is 6e23 atoms/gram. The primary challenge is converting the dose rate in Gy/s to an exposure rate at a distance of 100 cm from the target, with considerations for using a disk source approximation for the radiation emitted.
  • Understanding of neutron interactions, specifically the 1H(n,gamma)2H reaction
  • Knowledge of dose calculation in radiation physics
  • Familiarity with the concepts of exposure rate and its units
  • Basic principles of radiation geometry and point source approximation
  • Research the conversion of dose rate (Gy/s) to exposure rate (R/s) in radiation physics
  • Study the principles of radiation shielding and attenuation in water
  • Learn about the geometry of radiation sources and how to model disk sources
  • Explore the use of Monte Carlo simulations for neutron transport and interaction analysis
Students and professionals in nuclear physics, radiation safety officers, and anyone involved in radiation dose assessment and exposure calculations.
Phillyfan321
A beam of thermal neutrons (10^12 neutrons per cm^2 second) strikes a 1cm thick water target normal to its surface. The target is a round disk with diameter 20cm. Find the exposure rate (R/second) 100cm beyond the water target (the middle of the disk) from only the 1H(n,gamma)2H reaction. Ignore attenuation in water and air. Atomic density is 6e23 atoms/gram.
The only real equation I know if for dose calculation, not exposure.
D(n,gamma) = 1.6e-13 (J/MeV) * Flux * Number atoms (given) * cross section of hydrogen * Energy gamma * AF
I can get a value for the dose rate created from the (n, gamma) reaction, but am unsure how to get exposure 100cm past that point. The above formula gives a Dose rate absorbed in the water shield (we often used water as a substitute for tissue anyway). Would it be logical to create a secondary equation with the water disk as a disk source of radiation that is irradiating the point 100 cm away from its center? If so, how would a number in Gy/s be converted back to something usable to calculate exposure.
I guess so. A point-like source might be a good approximation as 100 cm >> 10 cm.
Don't calculate energy values - the formula you posted multiplies gamma photons per time with their energy, you can remove the energy part to get photons per time. Then you just have to take the distance into account.
