Extended Coulomb's Law: Need Help w/ LaTeX
  • Thread starter Thread starter MARTIN LOPEZ
    Law
MARTIN LOPEZ
I FOUND THIS EXPRESSION TO AN EXTENDED COULOMB´S LAW:
F = (k*q1*q2/r2)(1 -v2/c2)
BUT I NEED TO USE THE LATEX...HELP
SOMEBODY COULD HELP ME?
The formula is wrong, but in Latex it would be
F=q_1 q_2(1-v^2/c^2)/r^2.
if you separate the formula, may be you can begin to understand it, just do it and we continue
What does "separate" mean?
ok.
F = (kq1*q2/r2)*(1-v2/c2) = electric force (coulomb´s law) - magnetic force
F = (kq1*q2/r2) - (magnetic constant)*q1*q2*v2)/4*pi*r2
could some phenomena like this exists?
No, because the magnetic and electric fields of a moving particle are more complicated than you have assumed.
I´ve got two static charges in my hands and I measure the electric field, but I´m in a spaceship, just someone out of the spaceship see the magnetic field. How many complicated things see that observer?. I measure electric fields in the earth. What´s the traveling speed of the Earth around the Universe?
The relativistic formula for the fields of a moving charge are in most advanced EM textbooks. They enter to order v^2/c^2, which is too small to see with the Earth's velocity. But the v^2/c^2 correction to E is of the same order as the v^2/c^2 magneitc effect.
What is the relativistic formula for the fields of a moving charge?
What is the relativistic formula for the forces of a moving charge?
Grab an E&M book, as clem says, or look here: http://farside.ph.utexas.edu/teaching/jk1/lectures/node26.html"
I´ve got an article "Conceptual error in contemporary science", the author is: Joseph J. Smulsky. He presents a formula very similar to the formula shown in The electromagnetic field due to a uniformly moving charge. Which one is right?
I wanted to establish an equilibrium forces equation and I got the formula I present.
But F = (K*q1*q2/4*pi*r2)(1-v2/c2) it´s just a step for the complete equilibrium equation, there are more forces including fictitious forces.
I calculated using biot-savart law and lorentz force the magnetic force and I was adding terms to the equation.
Finally I wanted a formula for electron velocity in atomic structure
