Electricity Laws for 5km Extension Cord Use
  • Thread starter Thread starter quicksilver123
    Extension
The discussion revolves around the laws governing electricity transmission over a distance of five kilometers using extension cords. Participants explore various aspects including voltage drop, current limitations, wire gauge, safety risks, and the implications of using different types of plugs. The context includes both theoretical considerations and practical applications, with a focus on safety and feasibility.
  • One participant questions the understanding of Ohm's Law and highlights the issue of voltage drop over long distances with standard extension cords.
  • Another participant emphasizes the need for step-up and step-down transformers when transmitting high current over long distances.
  • Concerns are raised about safety code violations and the potential dangers of using such a long extension cord, including risks to insurance and personal safety.
  • Participants discuss the practicality of using a generator on-site versus the challenges of transmitting power over long distances with heavy gauge wire.
  • There is mention of the costs associated with using large gauge copper wire and the impracticality of the proposed setup.
  • Some participants suggest consulting a professional electrical engineer or power company for safe and effective solutions.
Participants express significant disagreement regarding the feasibility and safety of using a five-kilometer extension cord for power transmission. While some emphasize the impracticality and dangers, others explore the theoretical aspects without reaching a consensus on the approach.
Participants note limitations related to safety codes, the weight of the wire, and the potential for fire hazards. There are unresolved questions about the specific voltage levels that would be advantageous for such a setup.
This discussion may be of interest to individuals exploring power transmission, electrical engineering students, or those considering unconventional power setups in remote locations.
quicksilver123
So, complete hypothetical on laws governing power transmission over a distance:
Lets say I have a generator as a source of power - and attached to that is FIVE KILOMETERS worth of extension cords. :)
In this situation, what laws of electricity do I need to look out for?
Voltage drop over distance?
Amp drop over distance?
Gauge of wire?
Risk of fire?
There also might be something I need to know about the extension cord itself - the plug and the power cable components, whether a three prong grounded plug would be more advantageous as opposed to an ungrounded, two prong plug, etc.
Please help me out :)thank you!
Do you understand Ohm's Law?
Power distribution is normally done by stepping the voltage way up at the source and then down again at the distribution center, so with JUST an extension cord you're going to have a problem with voltage drop over that distance unless you have an unrealistically thick "extension cord" or you are transmitting a trivial amount of current.
What is the purpose of your question? What is it that you really want to know how to do?
Thank you for the reply.
My goal is to transmit 100 amps five kilometres.
I will do additional research on Ohm's law.
You will definitely need step up and step down transformers.
Even more to the point, you DEFINITELY need to consult a professional electrical power engineer.
Are those quite heavy? Mainly on the end of the line, at the load, I have weight limitations.
What type of voltages would be considered advantageous and why?
I thought you were kidding when you said extension cord, 5 km. :warning::thumbdown::skullXbones:
Technical differences aside, you would violate numerous safety code laws. Your insurance would be invalidated. You could kill people.
Here on PF, we should never publicly discuss any wiring that violates the National Electric Code.
It's not residential. It's underground. Unpopulated private land
So you were deceiving when you said "complete hypothetical"
I'm expanding the hypothetical to get around the totally imaginary legal issues here.
Obviously wouldn't want a fire because that would be bad engineering
If you are actually going to connect from house service drop (mains in Britain) which is 100 amps default and hookup something 5km, it will not work.
On the practical side:
Get a generator that meets your needs, locate the generator at the destination site. Pay an electrician to wire everything up. Much, much safer, and hugely cheaper.
Your way or the impractical side:
Have you priced 5km of 1 gauge copper wire? See: http://diyaudioprojects.com/Technical/American-Wire-Gauge/
( you will see that AWG 1 gauge is cheapest suggested for your amp requirement. BTW: I see it for US$ 1.89 per foot. It weighs a little less than 1 US pound per foot. So we have ~16000lbs X 2 conducting wires on reels. You can probably ground it locally. Dunno. )
For AWG 1 voltage drop is .1236 ohms per 1000ft. 5km ~= 16404.2 feet X (number of conducting wires). Use Ohms law to see the destination voltage. You really would need 4/0 gauge which is much heavier and far more costly. This is an absolute no-go in terms of cost.
Do not try what you mentioned. For what you suggest: Get professional help from your power company. There may be a transmission line much closer to the destination. Have them create the line extension and service drop. Probably way less than the $100K cost in wire. There is also CAIC assistance in most states and in Europe.
My choice is a generator on site. Example Lowes has home standby's for under US$ 5000.
Well said. Thread is closed as a dangerous activity discussion.
14K
12K
10K
