Extracting Divisors: A Simple Guide for Adding Factors
  • Thread starter Thread starter soul5
3 replies · 2K views
soul5
Ok this is what I did
int n;
count << enter number;
cin >> n;
for (int i = 1 ; i < n ; i++ )
if ( n % i == 0 )
I could use some help please like how to I extract the divisor?
so I can add them. Thanks a lot.
Your if condition tells you if i is a divisor. Since you said you want to add up all the divisors you have to declare an identifier, say int sum=0; at the start.
So you can do this should the if statement be satisfied:
if(n%i==0)
sum += i;
If you're writing a function, then you'll want to return sum after you're done. Alternatively if you want all the divisors individually, one way is to initialise an integer vector, say vector<int> divisors (remember to #include <vector>), and use divisors.push_back(i); each time your if condition is true.
More importantly you can improve your program slightly by specifying your for loop as :
for(int i=1;i<=n/2;i++) since it is evident that there cannot be any divisors of n which is larger than n/2.
soul5 said:
int sum=0;
int n;
cin >> n;
for (int i = 1 ; i <= n ; i++ ) {
if ( n % i == 0 )
sum += i;
count << " sum is " << sum << endl;
changed again
Well it looks ok to me. You forgot a semiconlon for your sum statement though. The best way to know if it'll work is to actually try it out. One thing overlooked earlier: your for loop doesn't allow i to be "n", which it should, since for any number n, n itself is a divisor of n. So change it to i<=n.
