Extraction of a particular quantum state from a quantum circuit
The discussion revolves around the extraction of a specific quantum state, namely the superposition state $$\frac{1}{\sqrt{2}} (|01 \rangle + |10 \rangle)$$, from a quantum circuit that initially produces a state with a phase factor, $$\frac{1}{\sqrt{2}}(|01\rangle + e^{i\phi} |10 \rangle$$. Participants explore potential circuit components and methods to achieve the desired state.
  • Exploratory, Technical explanation, Debate/contested
  • One participant seeks to modify a quantum circuit to convert the state $$\frac{1}{\sqrt{2}}(|01\rangle + e^{i\phi}|10\rangle)$$ into $$\frac{1}{\sqrt{2}} (|01 \rangle + |10 \rangle)$$.
  • Another participant suggests that a beam splitter and a phase shifter could be used to achieve this transformation.
  • Further inquiries are made about the construction of the state and the origin of the phase $$\phi$$.
  • A participant references a circuit that produces the desired state but questions how to implement it with parameterized gates.
  • There is confusion expressed regarding the necessity of the original circuit, as some believe it already solves the problem.
  • A suggestion is made to refer to a specific paper that discusses setups involving bipartite states and outputs related to Bell states.
Participants express differing views on whether the original circuit already addresses the problem. There is no consensus on the best method to achieve the desired state or on the role of the phase $$\phi$$.
Participants have not fully clarified the assumptions regarding the phase $$\phi$$ or the specific requirements for the circuit components needed to achieve the transformation.
ubergewehr273
TL;DR
Created state ##\frac{1}{\sqrt{2}}(|01\rangle + e^{i\phi} |10 \rangle)## using a quantum circuit. I wish to further process this state to achieve ##\frac{1}{\sqrt{2}} (|01 \rangle + |10 \rangle)## in particular.
Hello everyone!
I'm trying to implement a quantum circuit that yields a superposition state $$\frac{1}{\sqrt{2}} (|01 \rangle + |10 \rangle)$$ I'm using parameterized gates to achieve this. I have been able to create the state $$\frac{1}{\sqrt{2}}(|01\rangle + e^{i\phi} |10 \rangle)$$ Is there a way to further process this state to achieve $$\frac{1}{\sqrt{2}} (|01 \rangle + |10 \rangle)$$ in particular?
Thanks!
This should be possible with a beam splitter and a phase shifter in one branch.
Thanks but I'm asking if some circuit components can be added somehow to process the former state to be the final state in question.
How do you build your state? where is phi coming from?
This is my reference circuit. This clearly produces the state ##\frac{1}{\sqrt{2}}(|01\rangle + |10\rangle)##. This is obviously until the measurement is done.
However, I'm trying to implement a circuit which essentially gives me a 50-50 chance of getting either ##|01\rangle## or ##|10\rangle##. And with this condition in mind, I am able to produce the state ##\frac{1}{\sqrt{2}}(|01\rangle + e^{i\phi}|10\rangle)## with some arbitrary ##\phi##. What I want to know if some further processing quantum gates can be done to produce the particular state with ##\phi = 0## $$\frac{1}{\sqrt{2}}(|01\rangle + |10\rangle)$$
Seems like a questions for @Strilanc ...
That said, I am still a bit confused about the question. The circuit you show already solves this problem; are you trying to come up with another implementation using parameterized gates?
Also, what is phi? It is obviously a phase, but where does it come from?
Such a device would transform 01-10 into 01+10 (a bell state into another one)
  • · Replies 61 ·
