Analyzing f(x) = 2x + cotx: Concavity and Extrema
  • Thread starter Thread starter LearninDaMath
The discussion focuses on analyzing the function f(x) = 2x + cot(x) over the interval [0, π], specifically addressing its increases, decreases, concavity, and inflection points. The first derivative, 2 - csc²(x) = 0, leads to critical points at x = π/4 and x = 3π/4. The second derivative, f''(x) = 2cos(x)/sin³(x), is set to zero to find inflection points, resulting in x = π/2 as the only valid solution within the specified interval. The participants clarify the importance of isolating terms correctly when solving trigonometric equations.
  • Understanding of first and second derivatives in calculus
  • Knowledge of trigonometric functions, specifically cotangent and cosecant
  • Ability to solve equations involving trigonometric identities
  • Familiarity with the concept of concavity and inflection points
  • Study the implications of critical points in the context of f(x) = 2x + cot(x)
  • Learn how to apply the First Derivative Test for determining increases and decreases
  • Explore the method of finding inflection points using the Second Derivative Test
  • Practice solving trigonometric equations involving multiple terms and identities
Students and educators in calculus, particularly those focusing on function analysis, critical points, and trigonometric equations. This discussion is beneficial for anyone looking to deepen their understanding of concavity and extrema in calculus.
LearninDaMath
Analyze the function f(x) = 2x + cotx over the interval [0,pi] and state the increases/decreases and concavity.
I already found the first and second derivatives. However, I'm having trouble when setting them equal to zero.
2 - csc2x = 0
and
2(cscx)^2(cotx)^2 = 0
2 - cscx^2 = 0
cscx^2 = 2
maybe 1/sinx^2 = 2
maybe (1/sinx)^2 = 2
and then I'm stuck...
Pause with 1/(sin(x)^2)=2. Use algebra to rearrange that to sin(x)^2=1/2. Do you know how to do that? I'm not sure why you are getting stuck. You are doing fine so far.
Thanks for the help. Yea i was doubting whether I should isolate sinx or just x. I was able to arrange the equation and solve for the angles to get x = pi/4, 3pi/4 since the interval is [0,pi].
However, I'm getting stuck when trying to find the inflection points. The second derivative is 2cosx/sin(x)^3. I know cosx/sinx is cotx. But the power of 3 in the denominator is throwing me off. Also, I know is easier to find the angles of sinx and cosx than cotx, but is it necessary for the equation to be isolated into one trig term, such as cotx = (stuff), or can this be arranged to where sinx and/or cosx = (stuff)?
Ultimately, I am stuck at f"(x) = 2cosx/sin(x)^3 = 0 with little to no idea of what to do.
\frac{2\cos x}{\sin^3 x}
You are trying to differentiate this right?
There are a couple ways you can do this. Start off with the constant rule.
2 (\frac{\cos x}{\sin x^3}
Hint: \frac{a}{b^2} = \frac{a}{b}\frac{1}{b} or \frac{1}{x} = x^{-1}
There is also a simple differentiation rule that is very helpful in calculus I. Rings a bell?
No sorry, that is already the second derivative of the original function I posted.
I am trying to solve f"(x) = 0 for f"(x) = 2cosx/sin(x)^3 = 0
Take the denominator and set it equal to 0. The values of x you find will be values that CANNOT be in the solution set.
Then take the numerator and set it equal to 0. Remove from this solution set any values of x that also make the denominator equal to 0, if there are any.
So 2cosx = 0, so x should be 2(∏/2) and 2(3∏/2).
so x = ∏ and 3∏
Since the interval given in the problem is [0,∏],
the only allowable x value is x = ∏
Now setting (sinx)^3 = 0
I would guess sinx = 0, x = 1 and -1 and since its to the 3rd power,
the x values are x = (1^3 and -1^3) or maybe (\sqrt[3]{1} and\sqrt[3]{-1})
Are either of these correct?
So since none of the denominator roots = the numerator roots, then it stands that the only x value to make 2cosx/(sinx)^3 = 0 within interval [0,∏] is:
x = ∏
And if this is the correct answer, is the way I arrived at that answer correct?
And if its not correct, how do I solve and think about this problem?
Wait a minute...
2 should not be included in setting cosx = 0
because 2 can be made a separate term and set equal to zero, such as 2≠0
So I just have to set cosx = 0, which is x = ∏/2 and 3∏/2
And since they still don't match the denominator's roots,
x = ∏/2 is my revised guess.
If this is correct, is my method/reasoning correct?
If not, why and how do I get the correct answer?
No, that's not right. sin 1 ≠ 0. Also, does (-1)3 = 1?
of course, so if sinx = 0 , x = 0 and x = ∏
would that mean that sinx^3 = 0, x = \sqrt[3]{0} and \sqrt[3]{∏}
which means those two values are undefined
and that the values of the numerator can't equal 0 or ∏,
And since the values of the numerator equal 2/∏ and 3∏/2,
The only x value that exists within the given interval [0,∏] is x = ∏/2
Is this correct?
No, that's not right either. You're getting confused with regards to the cube root. From
\sin^3 x = 0
take the cube root of both sides first.
\sqrt[3]{\sin^3 x} = \sqrt[3]{0}
\sin x = 0
Then find x, which you did (0 and π).
The rest looks okay to me.
Yea, I was confused between getting the values x = (0, ∏) and x = (^3√0, ^3√ ∏)
This was my guess that lead me to the incorrect answer
sin^{3}x = 0
arcsin^{3}0 = ∏
^{3}√arcsin^{3}0 = ^{3}√∏
arcsin0 = ^{3}√∏
sin(^{3}√∏) = 0
...and the same process for the other x value of 0.
But now I realize that sin^{3}√∏ can't equal 0
Because it is sin∏ that equals 0!
So now I believe I understand why its correct to take the cube root of both sides first as you said.
14K
