Face Chromatic Number of A Graph
  • Thread starter Thread starter Cuttlas
    Graph
The discussion revolves around determining the face chromatic number of a given graph, with participants presenting differing opinions on its value based on visual representations and theoretical reasoning.
  • Participants are questioning the validity of the face chromatic number being 4, with some suggesting it is 2 based on their own colorings of the graph's faces. There is a discussion on the implications of vertex chromatic numbers and the characteristics of bipartite graphs.
The conversation is ongoing, with participants expressing confusion and seeking clarification on the correct face chromatic number. Some guidance has been offered regarding the properties of bipartite graphs, but no consensus has been reached.
Participants are grappling with the definitions and properties of face chromatic numbers versus vertex chromatic numbers, and there is mention of visual representations that may influence their understanding.
Cuttlas
Hi
What is the face chromatic number for the Graph Below?
Thank You
Four.
Why is it 4? Look at image below, the face chromatic number is 2, so it should not be 4. Could u please explain for me how did u get 4?
It can't be the chromatic number of the vertices either, because that's equal to 3.
The chromatic number of a map with one ore more closed loops as borders is always 2. You get a bipartite graph with all the nodes that are separated from the outside with an odd number of borders on one side, and those separated by an even number of borders on the other side.
If It can not be 2, then How I painted the Graph's Faces with only two colors? As you can see Faces in painted graph with different colors is not Adjacent with each other. So it means I did the painting correctly. But I think I'm mistaking. Could u please upload the painted graph which u think it is right?
I think willem2 was agreeing with you that the face chromatic number is not 4.
:) Yes, it seems your right. Then Does it mean I'm right? The Face chromatic number is 2 or 3?
Your own diagram seems to prove it's 2. Why are you unsure?
