How do I factor out negative signs in equations?
  • Thread starter Thread starter sobergeek23
    Factoring Negative
The discussion focuses on the process of factoring out negative signs in algebraic equations, specifically in the expression \((3a+4b)(a-3b) / (b(3a+4b)) \times (1 / (b^2(3b-a)(3b+a)))\). Participants clarify that \((3b-a)\) can be rewritten as \(-1(a-3b)\), allowing for cancellation with \((a-3b)\) in the numerator. The final simplified expression is confirmed as \(1 / (b^3(a-3b))\), emphasizing the importance of tracking negative signs during simplification.
  • Understanding of algebraic expressions and simplification techniques
  • Familiarity with factoring and negative signs in mathematics
  • Basic knowledge of fractions and cross-cancellation
  • Ability to use LaTeX for writing mathematical equations
  • Study the rules of factoring negative numbers in algebra
  • Learn about cross-cancellation techniques in rational expressions
  • Explore LaTeX formatting for writing mathematical equations
  • Practice simplifying complex algebraic fractions with negative signs
Students, educators, and anyone involved in algebra who seeks to improve their understanding of factoring and simplifying expressions with negative signs.
sobergeek23
Member warned that the homework template must be used
i have no idea how to use the punctuation marks for writing equations..ill do my best..
(3a+4b)(a-3b) over b(3a+4b) multiplied by 1 over b^2(3b-a)(3b+a)
during the cross cancelling the 3b-a would be multiplied by a negative one to switch the problem over right? (-1)(3b-a) in order to cross cancel with the (a-3b) in the top left..
the answer was 1 over b^3(a-3b) but i don't understand the whole negative sign thing..isnt (3b-a) the same as (-a+3b)? so factoring out the negative would make it (a-3b) and it cancels with the top left fraction but then i also have the (b) (b^2)(3b+a) on the bottom so how do they get b^3(a-3b)? i get the b^3 part ..i thought maybe the negative one i factored out in the (3b-a) would have also applied to the (3b+a) but then wouldn't it be (-3b-a) ..im so confussed on factoring out negatives..
Sure there isn't a typo? What happened to ##(3b+a)##?
see above
I don't really see where the ##-1## has gone to, neither in the quoted answer nor in the confusion of your reasoning.
To write formulas, you should read
https://www.physicsforums.com/help/latexhelp/
It's not that difficult but makes reading a lot easier. I think you have all you need to simplify the quotient. Just keep track of your parts. A simple trick to see, whether a step is write or wrong, is to plug in some small numbers for ##a## and ##b##, like ##\pm 1## or ##\pm 2##.
Was it the problem?
\frac{(3a+4b)(a-3b)}{b(3a+4b)}\frac{1}{b^2(3b-a)(3b+a)}
=\frac{(3a+4b)(a-3b)}{b(3a+4b)}\frac{1}{-b^2(a-3b)(3b+a)}
You canceled out a-3b, and you got a (-1) factor in the denominator. Dividing by -1 makes the sign of the whole fraction negative, so it is
-\left(\frac{(3a+4b)}{b(3a+4b)}\frac{1}{b^2(3b+a)}\right)after further simplification, you get the desired formula.
The minus sign is the same as a factor of (-1).
Remember the rules when calculating with factors. \frac{a}{bc}=\frac{1}{b}\frac{a}{c}
If b = -1,
\frac{a}{-c}=\frac{1}{-1}\frac{a}{c}
and you know that \frac{1}{-1}= -1
so \frac{a}{-c}=-\frac{a}{c}
#3 ..writing it out not that hard? looking at that page just made my eyes cross and my brain short circuit..ugh forget it..
Can you write (3a+4b)(a-3b)/( b(3a+4b))? Is that easier than writing \frac{(3a+4b)(s-3b)}{b(3a+4)}? Basically, that's all there is to it!
When you write x = \frac{a}{b} in LaTeX, you get ##x = \frac{a}{b}## after you enclose everything between two # symbols, like this: # # your stuff # # (remove spaces between the two # signs at the start and the end). Using # delimiters produces an "in-line" formula. If you want a "displayed" formula/equation, like this
$$ x =\frac{a}{b},$$
you should replace the # symbols by $ signs, so write $ $ your stuff $ $ (with no spaces between the two $ signs at the start and the end).
no idea what that means...the first thing u wrote made sense, the rest way over my head..this site won't let me post pictures either otherwise id just upload a pic of the problem
