Factorising Polynomials in Z[x]
  • Thread starter Thread starter pivoxa15
    Elements
Factorizing polynomials in Z[x] is complex due to Z not being a field, which limits the application of certain theorems. A common approach involves mapping polynomials from Z[x] to Q[x] to utilize theorems applicable in fields, allowing for factorization in Q[x]. However, if the resulting factors have coefficients not in Z, they cannot be mapped back to Z[x], indicating they are not factorable within that domain. Gauss' lemma is referenced, highlighting that a polynomial is irreducible over Z if it is irreducible over Q, but the reverse does not hold. Ultimately, the discussion emphasizes the challenges of finding integral roots and the necessity of rigorous justification in the factorization process.
pivoxa15
How do you factorise polynomials in Z[x]? Z is not a field so you can't use the theorem 'a is a root of f <=> (x-a) divides f'
Would you map the polynomials from Z[x] to Q[x] by multiplying by 1, since all elements in Z[x] are in Q[x]. Then factorise in Q[x] usiong the theorem above. If the factors have coefficients in Z than map (multiply by 1) these back to Z[x] so you have factorised these polynomials and they exist in Z[x]. If the factors in Q[x] have coefficients not in Z then you can't map back to Z[x] hence these are not factorisable in Z[x].
Is this how you would factorise polynomials in Z[x], formally?
Look up Gauss' lemma.
How does Gauss' lemma help?
What makes you think passing to Q[x] suddenly makes things easier? What is the factorization ox x^2-2 in Z[x]? And in Q[x]? The x-a a root thing is still as valid/not valid in Z[x] as in Q[x]. In fact that is what (one of) Gauss's Lemmas states: a poly is irreducible over Z iff it is irreducible over Q.
You factorise it 'by doing it'. I.e. trying to find a factorization. In general this is *very hard* and can't be done by any decent analytic means. It is however possible to show there are no integral roots by exhaustion.
Really? Second bullet point. If a poly is irreducible over Z it is irreducible over Q. (Obviously if it is reducible over Z it is reducible over Q).
Right. But the second point only has one way from the integers to the rationals. You had iff in your previous post?! Consider f(x)=2x^2+2x+2 is irreducible in Q[x] but is reducible in Z[x] i.e f(x)=2(x^2+x+1).
Anyhow, if you follow my method, and map the polynomials to Q[x] then you can (potentially) factorise by finding zeros of it (which is allowed by the theorem). Then follow two implications,
Let f(x) by original polynomial in Z[x]
1. f(x) primitive in Z[x] and irreducible in Q[x] => irreducible in Z[x]
2. f(x) is monic and reducible in Q[x] => reducible in Z[x]
It was convienent that all f(x) I was interested in factorising were monic hence also primitive so by mapping them to Q[x] I was able to tell if it was irreducible or reducible in Z[x], rigorously. If the word is appropriate here.
But would you say 'mapping' is a good word here? I am merely factoring specific polynomials given to me which were said to be in Z[x]. But I chose to test reducibility in Q[x]. Is a map really needed here? If not than what should I say or justify me taking the polynomials to Q[x] and doing the maths?
I pointed out the 'other' direction. It is trivial: irreducible over Q implies irreducible over Z. That really is trivial.
But what about
f(x)=2x^2+2x+2 is irreducible in Q[x] but is reducible in Z[x] i.e f(x)=2(x^2+x+1) with neither 2 nor x^2+x+1 is a unit in Z[x]
So you need
Correct?
The definition of irreducible I use is, P is irreducible <=>
P is non unit and if p=ab than a is a unit or b is a unit
What about my mapping question in my previous post? Is it appropriate?
Ok, modulo trivialities like dividing by a constant, jeez are you missing the point.
  • · Replies 17 ·
  • · Replies 18 ·
