Falling Cantaloupe - Distance Above Ground
Catchingupquickly
A cantaloupe with a mass of 0.45 kg falls out of a tree house that is 5.4 meters above the ground. It hits a tree branch at a speed of 6.3 m/s. How high is the tree branch from the ground?
## \Delta h = \frac {v_i^2 - v_f^2} {2g} ##
Given:
g = 9.80 ## m/s^2 ##
inital velocity = 0
final velocity = 6.3 m/s
mass = 0.45 kg (but here it's a red herring)
## \Delta h = \frac {0 - (6.3 m/s)^2} {(2) 9.80 m/s^2}
\\= \frac {-39.69} {19.6} ##
= -2.025 meters
So 5.4 meters - 2.025 meters = 3.375 or 3.38 meters above the ground.
Am I correct?
Given:
inital velocity = 0
= -2.025 meters
Am I correct?
You could always check by calculating it a different way. For example, here is a quick check:
With gravity at ##9.8 m/s^2## it takes about ##0.65 s## to reach ##6.3 m/s##. If gravity were ##10 m/s^2## it would be ##0.63 s##, so it's a bit more than that.
The average speed when falling from rest is half the final speed, so that's approx ##3.1 m/s##.
##3.1 \times 0.65 \approx 1.95 + 0.06 = 2.01##
So, the object fell about ##2 m##.
