Falling Cat - Rotation with Zero Total Angular Momentum
- Level: High School
- Thread starter A.T.
- Start date
13 replies · 4K views
Discussion
- 11,327
- 8,758
Wow. That's very clever. I'll have to re-watch it several times to grok the zero total.
- 4,364
It is easier to grok, when you imagine the cat bends 180° into a U-shape. Then its obvious that the ends of the U have opposite angular momenta. But real cats do not bend than much, so you need vectors.anorlunda said:Wow. That's very clever. I'll have to re-watch it several times to grok the zero total.
Homework Helper
- 587
- 329
For a similar analysis with squirrels, check out this hilarious video by Mark Rober, an engineer with way too much time on his hands. Link should take you to 15:59 where the discussion begins.
Spinnor
- 419
At the 1:07 point of the following video is an upside down cat which is dropped, best watched I think at 1/4 speed.
I think the physics is more complicated then explained in post 1?
See the 0:00 mark and the 1:54 mark for more analysis of the problem in the following video,
I don't who is right I am just suspicious of the answer given by A.T., the first video of the falling cat does not seem to jive with A.T.'s explanation. Maybe a combination of both explanations?
Thanks.
Thanks.
- 4,364
My video explains the core mechanism of how it is possible physically. Nature, especially biology is always more complex. The motion of a real cat's halves is often less symmetrical, which is likely dictated by physiology and preferred landing pose to dampen the impact better.Spinnor said:I don't who is right I am just suspicious of the answer given by A.T., the first video of the falling cat does not seem to jive with A.T.'s explanation. Maybe a combination of both explanations?
Spinnor
- 419
A.T. said:My video explains the core mechanism of how it is possible physically. Nature, especially biology is always more complex. The motion of a real cat's halves is often less symmetrical, which is likely dictated by physiology and preferred landing pose to dampen the impact better.
I got distracted looking for differences in the video I posted and forgot to like your video which immediately makes clear the general physics of the cats motion. Looking at old posts of mine gave me another chance to like a great video. Thanks.
- 4,364
You're welcome. Both Destin and Mark Rober in the videos linked above correctly point out that real animals sometimes turn around the front of the body first, then the back, by varying the moments of inertia. Likely because they prefer to see where they are going and/or want to land on a certain pair of legs first. But in other videos, especially when a cat falls from a small height and has to turn very quickly, it is more symmetrical like in my video.Spinnor said:I got distracted looking for differences in the video I posted and forgot to like your video which immediately makes clear the general physics of the cats motion. Looking at old posts of mine gave me another chance to like a great video. Thanks.
256bits
- 2,297
when are you going to do a simulation summersalt ( somersault - phonetics is great ) with twist off the diving board.A.T. said:You're welcome. Both Derek and Mark Rober in the videos linked above correctly point out that real animals sometimes turn around the front of the body first, then the back, by varying the moments of inertia. Likely because they prefer to see where they are going and/or want to land on a certain pair of legs first. But in other videos, especially when a cat falls from a small height and has to turn very quickly, it is more symmetrical like in my video.
Here some math people envision a 1.5 rotation with 5 twists as being possible.
https://www.technologyreview.com/20...ly-new-dive-with-5-twists-and-15-somersaults/
A PDF from the arxiv
https://arxiv.org/abs/1612.06455
Spinnor
- 419
256bits said:when are you going to do a simulation summersalt ( somersault - phonetics is great ) with twist off the diving board.
Since height is a limiting factor to more twists I wonder if any trainging facility might add height to the diving platform and then vary the height
One limiting factor in the above analysis of the number of possible twists is platform height. It would be "easy" to make a diving platform with an adjustable height. Nail the 5 twists at a height greater than 10 meters and then as technique improves lower the platform towards 10 meters? A quick Google search does not come up with such an adjustable training platform.
- 22,832
- 14,881
Well, height here is just a proxy for time. One easy way to increase time is to be in free fall, for example in orbit at the ISS or parabolic flight.Spinnor said:One limiting factor in the above analysis of the number of possible twists is platform height.
- 4,364
In the below parabolic flight video at 0:11 a cat makes ~8 rotations in 5sec.Orodruin said:Well, height here is just a proxy for time. One easy way to increase time is to be in free fall, for example in orbit at the ISS or parabolic flight.
In most zero-g videos I saw cats just float around and relax. But here the evil NASA guy was throwing it against the wall.
Spinnor
- 419
From Google search "gymnastics slow motion twisting angular momentum"
https://www.youtube.com/results?search_query=gymnastics+slow+motion+twisting+angular+momentum
Has anyone ever suspended a gymnast upside-down, like a cat by its paws, and let them go to see if they could land on their "paws"? The guy in the video looks like he could have done so? This could be done over a pool or a foam pit so the gymnast was not hurt.
Thanks.
Edit, start the video at 2:21 to see the gymnast do a "cat twist".
- A.T.
- · Replies 2 ·
- Mechanics
- Replies
- 2
