Falling into a Volcano: Fact or Fiction? The Truth Behind the Myth
  • Context: Undergrad
  • Thread starter Thread starter Mitchtwitchita
    Falling Volcano
The discussion centers around the question of whether a person would sink or float if they fell into a volcano's magma pool. Participants explore various factors influencing this scenario, including density differences, surface tension, and the physical properties of magma. The conversation encompasses theoretical reasoning and speculative scenarios related to human interaction with volcanic magma.
  • Some participants argue that the density difference between water and magma suggests a person would float, while others contend that gravity would cause a body to sink, breaking the surface tension of the magma.
  • One participant notes that the composition of the body and the extreme heat of the magma would affect the outcome, potentially leading to the body becoming part of the magma.
  • Another participant raises the idea that the presence of a crust on the magma could influence whether a body would sink or float.
  • There is a request for mathematical analysis regarding the force required to break the surface tension of water, with specific values provided for surface tension at certain temperatures.
  • Confusion arises over the interpretation of surface tension values and their application to the scenario, with participants seeking clarification on the required force to breach it.
  • Some participants express frustration over misinterpretations of the original question, emphasizing the need to focus on the sinking aspect rather than anthropological or archaeological implications.
Participants do not reach a consensus on whether a body would sink or float in magma, with multiple competing views and interpretations of the scenario remaining unresolved.
The discussion includes assumptions about the physical properties of magma and water, as well as the effects of temperature and composition, which are not fully explored or agreed upon.
Mitchtwitchita
Recently, there has been an argument of whether or not you would sink if you were unlucky enough to fall into a volcano. The proponents of this argument focus their attention on the water/magma density difference. Since the human body consists of 60-70% water, and water is less dense than magma, the proponents of this argument conclude that you would not sink. Rather, you'd act like a water balloon hitting a wall. However, the argument neglects to mention such things as composition, acceleration due to gravity, and the extreme heat.
My contention is that the force of gravity, as one fell from the cone, would be sufficient enough to break the surface tension of the magma and sink. Additionally, as the body sank, the water would be drive off and the elements in the body would very quickly become part of the composition of the magma. Also, the gaseous component of the magma would allow for us to sink more readily depending on the abundance.
Here's the site for the argument:
http://www.lifeslittlemysteries.com/sink-fall-volcano-lava-2225/
What do you guys think?
Sounds like an archeology / anthropology question. "When humans were sacrificed to the gods by being thrown into a volcano, did they sink or did they float?"
Likely there are still some cultures where larger animals (e.g., pigs) are sacrificed in the boiling magma cauldron.
Might depend a lot on whether or not it has developed a crust.. The non-glowing crust would be rock hard.
@ NascentOxygen, Umm, it may be my fault for not articulating the question well enough but, what I'm interested in is whether or not a body would sink if that same body were unfortunate enough to fall from the ledge of a cinder cone into a pool of magma?
Zula110100100 - Say that the surface layer has not reached a temperature in which it is able to cool sufficiently?
In general, some math would be dynamite. Like, the force it takes to break the surface tension of water. I can make assumptions from there...
Zula110100100 - I was curious as to what applied force would break the surface tension of water? Maybe even a known equation that could apply would be dynamite? I do thank you for your input. I'll try to apply it...
I'm also confused as to your notation. because 72.8 mN/m = 72.8N. Is this the required force in order to breach the surface tension?
LOL, I'm an idiot. I got you man. Thanks Zula!
What's it matter how you got there--whether through taking a tumble, or being pushed? In either case, it's curtains!
Well, it doesn't matter how one would fall.
What would matter is how the question is interpreted though. And, I don't feel as though you're understanding the question correctly, NascentOxygen. It's neither an archaeological question, nor is it anthropologic. Rather, it's a question of whether or not one would sink if they were unfortunate enough to fall from the edge of a volcano into its magma pool.
  • · Replies 21 ·
10K
