Falsity of assumptions question.
  • Level: Graduate
  • Thread starter tylerc1991
    Assumptions
tylerc1991
In the course of proving that [itex]\sqrt{3}[/itex] is irrational, I had another question pop up. To prove that [itex]\sqrt{3}[/itex] is irrational, I first assumed 2 things: [itex]\sqrt{3}[/itex] is rational, and the rational form of [itex]\sqrt{3}[/itex] is in it's lowest form. I then broke the proof up into cases and showed that none of these cases could occur.
My question boils down to: did I actually show that [itex]\sqrt{3}[/itex] is irrational?
From a purely logical standpoint, let's say that the 2 assumptions I made were named A and B. I successfully showed that A [itex]\wedge[/itex] B is false. However, this doesn't mean that BOTH A and B are false. More specifically, A could be true and B could be false, and I would still arrive at A [itex]\wedge[/itex] B being false.
On the other hand, the second assumption that was made (the rational form of [itex]\sqrt{3}[/itex] is in it's lowest form) shouldn't (doesn't?) change the problem.
Could someone give me solace and explain this little technicality I have? Thank you very much!
If you are merely assuming that, then you do have a problem, and you have merely proved:
If sqrt(3) is rational, then it cannot be expressed as a fraction in lowest terms​
(or something equivalent)
But you don't have to merely assume that a rational number can be written in lowest terms, do you?
So this isn't really an assumption, per se? This is more of a 'without loss of generality' statement?
Right, although I wouldn't have chosen that phrasing.
