Family of Circles through Two Points: Exists Any Circle Beyond?
  • Context: Undergrad
  • Thread starter Thread starter Devil Moo
    Circles
The discussion revolves around the existence of circles that can be defined through two given points in a plane, exploring the mathematical formulation of a family of circles and whether all possible circles can be represented within this family. The scope includes mathematical reasoning and exploration of geometric properties.
  • Some participants propose that a family of circles can be constructed through two points using a linear combination of their equations, suggesting that varying a parameter can yield an infinite number of circles.
  • Others question the specific values of the parameter that would yield back the original circles in the family.
  • One participant argues that while the family of circles has one degree of freedom, the complete set of circles through the two points has three degrees of freedom, implying that not all circles can be represented by the family.
  • Another participant introduces specific examples of circles and discusses the implications of certain parameter values, noting cases where no solutions exist or where the resulting equations do not represent circles.
  • Some participants discuss the geometric interpretation of the centers of the circles and suggest that they lie on a straight line.
  • There is a mention of degenerate cases where the resulting equations may represent lines instead of circles.
Participants express differing views on whether all circles through the two points can be represented by the family of circles. Some assert that there are circles not included in the family, while others explore specific cases and examples that challenge or support this notion. The discussion remains unresolved regarding the completeness of the family of circles.
Limitations include the dependence on specific values of parameters and the conditions under which circles can be defined through the two points. The discussion also highlights the potential for degenerate cases where the equations do not yield circles.
Readers interested in geometric properties of circles, mathematical reasoning involving parameters in equations, and the exploration of families of geometric shapes may find this discussion relevant.
Devil Moo
Supposed 2 circles ##C_1 : x^2 + y^2 + {f_1}x + {g_1}y + h_1 = 0## and ##C_2 : x^2 + y^2 + {f_2}x + {g_2}y + h_2 = 0## through two points.
A family of circles can be constructed as ##x^2 + y^2 + {f_1}x + {g_1}y + h_1 + k(x^2 + y^2 + {f_2}x + {g_2}y + h_2) = 0##.
By altering the k, an infinitely number of circles through those two points are obtained. So is any circle existed that it cannot be obtained by the family of circles?
Well, for what value of ##k## does one get back ## C_2## ?
Let ##C = \{C_1, C_2, C_3, ...\}## be the set of equations of circles through those two points.
Can we get all the elements of ##C## from the family of circles?
You get back ##C_1## when choosing ##k=0##. But ##C_2## ?
Um... choosing ##\lim_{k \rightarrow \infty} k##?
You cannot do that, k has to be a real number. Do the variables have to have the same value for C2 and the class of circles?
If all the variables apart from k are fixed in the family of circles, then there are certainly circles not included in that family - your family has just one degree of freedom while the set of all circles in a plane has three.
##f_1, f_2, g_1, g_2, h_1, h_2## are fixed.
Do ##x, y## count as degree of freedom?Do ##f, g, h## have relationship to make circle passing through those points?
No, ##x## and ##y## are subject to the equations. ##f_1, f_2, g_1, g_2, h_1, h_2## are six degrees of freedom, but four of those are needed to let the circles go through the two points ##(x_1,y_1)## and also through ##(x_2, y_2)##. The other two can be found from the radii of ##C_1## and ##C_2##.
In the family of circles there is one degree of freedom (k). Makes sense, because the centers of the circles are constrained to be located on the perpendicular bisector of the line segment from ##(x_1,y_1)## to ##(x_2, y_2)##.
But ##C2## isn't in the family...
How about modify the argument that exclude ##C_2##?
I am not sure what you mean with that question ?
Devil Moo said:
Do x, y count as degree of freedom?
No.
Your family of circles is not necessarily a family of circles, by the way. Many pairs of circles lead to empty sets for the second equation.
How about now ##C = \{ C_1, C_3, C_4, ...\}##?
Sorry. I do not get it.
As example, consider:
C1: ##x^2+y^2-4x-4y+7=0##
C2: ##x^2+y^2+4x+4y+7=0##
For k=1, how does the corresponding figure look like?
Ck=1: ##2x^2+2y^2+14=0##. Try to find solutions for that.
Not sure I like this example: C1 and C2 have no points in common...
I'm embarking on some real work now (yuck, against my nature) by bringing in another example:
##C_1 :\ x^2 + (y-1)^2 = 5\quad ## and ##\ C_2 :\ x^2 + (y+1)^2 = 5\quad ## with ##\ (-2,0)\ ## and ##\ (2,0) \ ## in common.
For ##k = -1## we get no solution, for ##k\ne -1## we get
$$C_k:\ x^2 + \left (y- {1-k\over 1+k}\right )^2 = 5 + \left ({1-k\over 1+k}\right )^2$$ if I'm not mistaken.
Circles through the two common points with center ##\ \left (0,{1-k\over 1+k} \right )\ ##.
That means we found an infinity of circles trough the two common points, but not all of them:
we don't have ##C_2## in the family, and got one black sheep (a no solution non-circle) in return.
Ah, the "through two points" mean they intersect. Okay, then it works, k=-1 as exception (where the equation becomes linear - it has solutions, but not a circle).
mfb said:
it has solutions
You're right - I made a sign error and overlooked that ##y=\pm {1\over 2}## solves ##C_{-1}##. Funny case.
The family of circles going through the two points in ##C_1 \cap C_2## is given by ##k_1(x^2+y^2 + f_1x+g_1y+h_1) + k_2(x^2+y^2 + f_2x+g_2y+h_2) = 0##, where ##k_1## and ##k_2## are not both zero. You retrieve the same circle whenever ##k_1## and ##k_2## are scaled by some constant ##\lambda \not = 0##. In other words, such a circle uniquely determines a point ##(k_1:k_2)## on the projective line ##\mathbb{P}^1## and vice versa. The degenerate case is the point ##(k_1:k_2) = (1:-1)##, in which case you end up with a line. In this sense, the affine line ##\mathbb{A}^1 \cong \mathbb{P}^1 \backslash \{(1:-1)\}## parametrizes the family of circles going through these two points.
When I construct a equation of circle passing through ##(-2, 0)## and ##(2, 0)## which is not ##C_2##, that equation can be retrieved by ##C_k##. If we plot the center of all circles passing through two points, I think it must be a straight line.
By this expression, does it obtain all circles and straight line passing through 2 points?
How come no one puts me right there ? ## (y+1)^2 - (y-1)^2 = 0\quad## gives y = 0. One single straight line through both points in the example. No 'funny case' at all, just a sensible limiting case.
Yep, the y-axis in the example. Minus the point ##(-1,0)## :smile:
Devil Moo said:
When I construct a equation of circle passing through ##(-2, 0)## and ##(2, 0)## which is not ##C_2##, that equation can be retrieved by ##C_k##. If we plot the center of all circles passing through two points, I think it must be a straight line.By this expression, does it obtain all circles and straight line passing through 2 points?
Yes. The degenerate case can also be thought of as a generalized circle.
Is k served as a parameter to choose the center points of the circle passing through those two points, for k != -1?
Yes.
