Faster-than-light communication
The discussion centers around the possibility of faster-than-light communication using entangled photons and polarization filters, exploring theoretical implications and experimental setups. Participants examine the mechanics of quantum entanglement, the role of polarization, and the potential for transmitting information through these systems.
  • Some participants question whether faster-than-light communication is feasible based on Alain Aspect's experiments with entangled photons and their polarization.
  • One participant suggests that switching polarization filters could allow for information transfer, but others challenge this by asking how such a method would work practically.
  • Another participant proposes that using a Bell test experiment could yield different probabilities of detection based on filter orientation, raising the question of whether this constitutes faster-than-light communication.
  • Several participants emphasize that entangled photons cannot be used to transmit information, noting that the results observed are random and do not convey a message.
  • There is a discussion about the role of observers and the potential for entangled quantum computers to make correlated decisions, but the feasibility of this as a communication method remains uncertain.
  • Participants express confusion about the mechanics of the experimental setups, particularly regarding the use of beamsplitters versus polarizers.
Participants do not reach a consensus on the possibility of faster-than-light communication. While some explore theoretical frameworks and propose methods, others firmly state that entangled photons cannot be used for information transmission, leading to ongoing debate and uncertainty.
Participants acknowledge limitations in their understanding of the experimental setups and the behavior of entangled photons, indicating a reliance on specific assumptions about the systems involved. There are unresolved questions regarding the implications of different configurations and the nature of the results produced.
Albert V
Many seem to be skeptical whether faster-than-light communication is possible. Consider the experiments performed by Alain Aspect where the polarization of one of the entangeled photons force the other to collapse into the opposite axis.
http://en.wikipedia.org/wiki/Alain_Aspect
The Wikipedia article says that the experiment do not demonstrate faster than light communicaiton and I wonder why.
If one of the polarization filters is switched from axis to axis, and the other filter kept steady, it should according to my logic, be possible to transfer information. What am I missing?
Learning information is different from transmitting.
How? Suppose e.g. that you flip a coin and want to send a 1-bit message (1="heads", 0="tails") to let someone at the other end know what the result was. How would you do this?
The information is sent like this:
Entangeled photons are created with a frequency that is known to the receiver. By keeping his filter steady he would have a "click" in his detector when a photon passes his filter, and a delay when the photon is stopped by the filter. If the experiment works like this it is possible to send a binary string of information. However, the problem seems to be that if the filters are adjusted to the same axis it will be random whether the photon is stopped by your filter, or the filter at the receiver. And I think it will be the same in a situation were you are located much closer to the photon transmitter (anhilation point) than the receiver.
Am I correct?
Ok, new idea:
By carrying out a Bell test experiment we will observe the following:
1) When the polarisers are oriented along opposite axis we will get clicks in both detectors
2) When the polarisers are oriented along the same axis we have 50% chance of getting a hit in the detectors at both sites.
Now we use 20 photons to transmit 1 bit of information. Data that gives us 100 % hits, versus data that gives us only 50 % hits.
Is this faster-than-light communication or can somebody tell me where I go wrong?
Best
Albert
Albert V said:
Ok, new idea:
Best
Albert
There are always clicks at the detectors, assuming you put a polarizing beam splitter in front of a pair of detectors. Each photon is randomly polarized. They wouldn't be polarization entangled otherwise. As previously mentioned, entangled photons cannot be used to transmit information.
You could try to create two entangled observers. A large quantum computer implements an observer. We take two such quantum computers and intitialize them in some mutually entangled state of the form
Sum over_j A_j |j>|j>
where |j> denotes some bitstring in a |0>, |1> basis which corresponds to some classical brain state of the observer and state of the virtual world the observer finds himself in. The quantum algorithm is such that bistrings in the |0>, |1> basis evolve deterministically. So, we assume that a classical determinisic algorithm can represent the mind of a real person.
Suppose that the two entangled quantum computer pairs are separated by a large distance. Then if one observer makes what is in his mind a random choice for some numbers, he knows that his copy will have made exactly the same decision.
Yes, this is also how I understand the system. I have taken this fact into account. Therefore one and one photon can not be used to transmit information. But let us start from the beginning with all my assumptions.
1) A continuous source of photons emitted at an even frequence
2) When the polarisers are oriented along opposite axis we will get clicks in both detectors (the receiver will therefor obtain clicks according to the given frequence. Let us say that 10 photons is enough data for him to conclude that the filter at the transmitter is oriented along the opposite axis)
3) When the polarisers are oriented along the same axis we have 50% chance of getting a hit in the detectors at both sites. In this situation the receiver will have clicks but also delays regarding the agreed frequence. Statistically he will have 50% less clicks than in the former situation. 10 photons gives him enough data to conlude that the filter at the transmitter is oriented along the same axis.
Sorry that I have to be spoonfed, but I need to know how these systems behave.
Best
Albert
Best
Albert
I think you may have a slight misunderstanding of what the actual setup produces in the way of results.
There are 2 observers, Alice and Bob. They get a stream of photons arriving as you say, perhaps 10. They EACH have a polarizing beamsplitter and 2 detectors. When Alice gets a dectector hit on the first detector, she marks it a +. The other detector registers as a -. Ditto for Bob.
Alice can vary her beamsplitter orientation so she can "send" a message. (Not really of course as we will find out.) Bob holds his beamsplitter fixed and steady so he can receive a "message". The beamsplitter separates the photons to one of the 2 detectors as mentioned, and he records a + or a - according to which of his 2 detectors fires.
Now what does Bob see when he records his results? He see a random series of + and - results, something like this:
Since the "message" is random, no information is received. It doesn't matter what Alice does, Bob's message is totally random by any measure. That is because the source of the entangled photons is random itself. The pattern that indicates there is entanglement is ONLY evident when Alice AND Bob's results are correlated.
Thanks Dr. Chinese for spending time one these questions.
I am a little confused by your beamsplitters because I am not familiar with how they work. I had a single channel Bell test in mind. And I use polarisers since they are more easy to understand.
After anihilation of a positron and an electron, two photons are generated with opposite directions and planes. The planes are not determined, but will be after one of the photons passes a polariser. Opposite orientation of the polarisers will always allow BOTH the photons to pass and same orientation will only allow one of the photons to pass.
Am I correct this far?
Yes, for this setup, and notice that coincidence matching (CM) is necessary. That does not allow an opportunity for Alice to send a message to Bob. Alice must first send her results to be matched with Bob's. That occurs at light speed. So no FTL possible.
DrChinese said:
Yes, for this setup, --
Hence, when the polarisers are oriented along opposite axis, Bob gets a message like this; ++++++++++, but when the polarisers are oriented at the same axis Bob will get a message like this; +delay++delay+delaydelay++ (where + signifies clicks at the preagreed frequence of photons)?
Am I also correct this far?
No, Bob ALWAYS gets a "message" (in your terms) like:
Meanwhile, Alice gets a somewhat similar "message" depending on her polarizer orientation. At some orientations it will be the same message, at some it will be opposite, and at others a mixture.
Keep in mind that Alice is located one place, and Bob is located at another. Each sees one side (one half) of the stream of entangled photon pairs. Assuming they were equidistant from the source, they would receive photons going into their respective polarizer simultaneously (within a narrow window). Since those photon pairs have random (but opposite) polarization, both Alice and Bob see random streams. When the streams are compared at a later time, and you know the respective polarizer orientations, you can detect that the source pairs were (or were not) entangled.
Two key points affect the results of an attempt to send a signal via entangled photons:
1. The setting on Alice's polarizer does not affect the result that Bob gets, for any individual photon. And vice versa, swapping Alice and Bob.
2. Also, neither Alice nor Bob can control the sequence of states in which the photons are produced. They can only control their polarizers.
First suppose that Alice and Bob both keep their polarizers horizontal. Each column indicates one photon pair. H and V indicate the polarizer settings, + and - indicate whether a photon got through that polarizer. They might get something like this. I generated Alice's sequence of + and - by flipping a coin thirty times.
Code:
Alice: HHHHHHHHHHHHHHHHHHHHHHHHHHHHHH
Bob:   HHHHHHHHHHHHHHHHHHHHHHHHHHHHHH
Now suppose that instead, Alice had kept her polarizer vertical, and Bob had kept his horizontal. For the same photons they would have gotten the following results
Code:
Alice: VVVVVVVVVVVVVVVVVVVVVVVVVVVVVV
If Alice had alternated between horizontal and vertical polarizations, in "chunks" of five photons at a time, with Bob keeping his horizontal the whole time:
Code:
Alice: HHHHHVVVVVHHHHHVVVVVHHHHHVVVVV
How does Bob extract Alice's "signal" (HHHHHVVVVVHHHHHVVVVVHHHHHVVVVV) from his data, when they cannot actually repeat the experiment with the same sequence of photons? Each time they repeat the experiment, they get a different sequence of photon polarization states, at random, like me flipping my coin another thirty times.
DrChinese & jtbell,
Isn't this thread an example of what you just told me in another thread was prohibited? It clearly is opposed to mainsteam theory. From your guidlines:
"It is against our Posting Guidelines to discuss, in most of the PF forums or in blogs, new or non-mainstream theories or ideas that have not been published in professional peer-reviewed journals or are not part of current professional mainstream scientific discussion."
And yet you made no objections and participated in it. Why?
Thank you both for being patient with me
This is the point where I don't follow
I said:
Opposite orientation of the polarisers will always allow BOTH photons to pass and same orientation will only allow one of the photons to pass.
DrChinese said:
Yes
If Bob keeps his filter horizontal and Alice keeps her filter vertical, why does not the frequency of photons passing the polarizer go up compared to the situation where Bob and Alice both keep their polarizers at a, let's say, vertical position?
Albert
I see now that these systems did not behave as I had understood. I thought that the wave-function collapsed into a certain plane when the photons hit a polarizer, well perhaps it does, but the plane can still be different from the orientation of the polarizer.
The measurer is unable to feed information into the system.
But what is the probability of passing photons. There are many more planes than horisontal and vertical.
I don't see why Einstein thought this was spooky. The planes of the photons are opposite, and that's it.
Thanks for helping me
Indeed, and the cases where the polarizers are not at right angles to each other, are the really "spooky" ones! In these cases you cannot explain the experimentally observed probabilities of photons passing through the polarizers (more precisely the correlations between pairs of entangled photons) by using a "natural" simple model that explains the case where the polarizers are at right angles.
Dr. Chinese's Web site has a lot of useful information and links to original papers related to entanglement and Bell's Theorem. For simplified examples that illustrate the "spooky" correlations see particularly
Bell's Theorem with Easy Math (Dr. Chinese's own example)
http://www.iafe.uba.ar/e2e/phys230/history/moon.pdf from Physics Today magazine (April 1985).
Yes, it is true that when you talk about opposite or parallel orientations, then there does not seem to be anything weird happening. Einstein essentially said that in such cases, the results must in fact be predetermined. This is often referred to as the Bertlmann's socks anaology (you can look it up if you like).
But that is not the tricky situation. Bell discovered that at other specific angles, the quantum statistics were incompatible with the idea of predetermination. Experiments have since shown that quantum statistics are correct, and the idea of predetermination cannot be.
So in the end, and to use Einstein's words: either there is spooky action at a distance or the moon is not there when no one is looking.
jtbell said:
Dr. Chinese's Web site has a lot of useful information and links to original papers related to entanglement and Bell's Theorem...
Thanks! And I have recently been expanding some of the references so that more advanced & related areas - such as GHZ, Leggett and Hardy - are also covered. For those not otherwise familiar with them: these theorems are separate but similar in conclusion to Bell. I.e. basically that realistic or local realistic theorems cannot hold.
Hi folks, I'm back with another idea. This would not be of any practical use, but it is interesting to discuss whether FTL is possible in principle.
We use a similar experimental setup:View attachment FTL.pdf
The principle for sending information will be the two states superposition (0) and polarized (1). Alice is the sender of the information and Bob function as a receiver.
In superposition it is possible to see a single photon interference on the screen (I don't know exactly how many photons that must hit the screen in order to produce an interference pattern, but it should be a limited amount - we assume that Alice and Bob know exactly how many in order for Bob to see a pattern or not. After this preeagreed number Bob resets the screen).
If Alice introduces a polarizer Bob will not see the interference pattern since his photon will be in a polarized stage and will not be able to interfere with itself, but choses the left or the right side of the wire (depending upon vertical or horisontal polarization) .
I am not sure what happens if Alice does not get a click in her detector. I assume that the photon still has taken on a value, and that the entangled pair is not longer in its superposition? But still, the presence of a polarizer should in the long run give another pattern on the screen than when not present.
By introducing and removing the polarizer, Alice should be able to send Bob a message.
We use a similar experimental setup:View attachment 19808
Great idea. (I came up with that one a few years ago myself before someone here shot me down.) The problem is that you don't get an interference pattern on Bob's side... ever. Entangled photons do not exhibit the kind of interference pattern you describe. This is a specific physical and detectable difference between entangled photons and "normal" photons.
You can see this in an enlightening article by Anton Zeilinger, p. 290, Figure 2.
Experiment and the foundations of quantum physics
"FIG. 2. A source emits pairs of particles with total zero momentum.
Particle 1 is either emitted into beams a or a' and
particle 2 into beams b or b' with perfect correlations between
a and b and a' and b', respectively. The beams of particle 1
then pass a double-slit assembly. Because of the perfect correlation
between the two particles, particle 2 can serve to find
out which slit particle 1 passed and therefore no interference
pattern arises."
Now, don't confuse the fact that you can get interference in SUBSETs of photons on Bob's side with being able to send a message. There are so-called "quantum eraser" experiments in which it superficially appears to show interference on Bob's side. And it does, but only in correlated subsets. I.e. you must send data from Alice's side to Bob so the subset can be correlated. Since that information must be sent no faster than light speed, you are back where you started.
I think that Zeilinger is not clear on this point:
When does our knowledge of the system interact?
Is it that the knowledge is "out there" in principle, but not yet obtained - or is it that we actually obtain the knowledge by performing a certain experimental setup?
pattern arises."
It's remarkable that I also had the same idea some time ago, and that I was inspired by the same Zeilinger paper above (which, as Albert also noted, is somewhat vague at some parts.) I needed few days to find out the mistake.
Let us try again with an eraser. Now I have no which path information. Do you mean, DrChinese, that the system still refuses to produce fringes on the screen?
View attachment FTL2.pdf
Quantum eraser version
OK: we agree that IF we choose to erase or not erase, and that conditions what we see at Bob (interference pattern or not), THEN we could send an FTL message.
So you have to believe as there is a Nobel for the person who figures that out, and Zeilinger would like one of those, so probably this setup won't serve for FTL. He has probably tried it once or twice just to be sure.
So now the question is: why not?
The answer is that when there is erasure of which path, there is an interference pattern... but that is a subset you cannot control or otherwise influence. How does Bob know which subset to use? He asks Alice. Of course, that doesn't get you very far because that communication must be performed at light speed or less.
Bob's pattern consists of 2 random subsets: one in which there is erasure and interference, and another in which there is no erasure and "anti-interference". The sum of the 2 subsets is a non-interference pattern. You can look at this paper for more information:
S. P. Walborn, M. O. Terra Cunha, S. Padua, C. H. Monken (2001): A double slit quantum eraser
It takes some time to get it, so don't be surprised if you can back and forth on it a while. :smile: You have to match the captions to the graphs, this version may be easier to see:
http://grad.physics.sunysb.edu/~amarch/Walborn.pdf
or this:
Good luck!
Well this is actually not my suggestion. I say we keep the eraser and introduce our polarizer in front of each detector again. The message is still sent by introducing and removing the polarizers. We just had to introduce the eraser to get rid of the which path information in order to get our inteference pattern back - but again I don't know whether the system will produce a pattern or not.
I guess that removing the eraser is equivalent.
And maybe Zeilinger has tried it, but doesn't want to tell us :smile:
That is true. Particles on one side do not produce interference fringes, no matter what you do with particles on the other side. The interference fringes that can be seen are not produced by particles on one side. Instead, they are a property of the correlations between particles on BOTH sides. But you cannot observe these correlations without conventional subluminal communication between the two sides.
I agree - it is actually easier to understand when you look at the math. It is the beamsplitter that actually filter out half of the photons by rotating them 90 degrees.
http://www.flownet.com/ron/QM.pdf
  • · Replies 40 ·
  • · Replies 24 ·
  • · Replies 56 ·
9K
  • · Replies 19 ·
  • · Replies 25 ·
