Faster-than-light experiments at home?
30 replies · 10K views · last reply
pallidin said:
OK, but if that is true, than I can transmit data FTL through vertex manipulation, so I question it's reality. Allow me to explain:
Using the 2 inclinded jaws as you described, the angle of separation(in this case) will cause a non-mass vertex movement to go FTL. Correct?
I can easily create sensors that determine whether or not a vertex exists at any given point. Agreed?
So, if I put a sensor at the beginning of the jaws to indicate vertex starting, and one at the end to indicate vertex arrival, the second sensor should "trigger" a vetex moment faster than C. Right?
With that I manipulate the jaws in Morse Code to transmit data FTL.
It's all true, except that you can't transmit data. You absolutely have to push the jaws together uniformly for the vertex to go FTL, such as with a uniform field pulling both jaws together, or one of them downward (gravity for example). To transmit data, you would have to be able to push the jaws together from one end, which you can't do (jaws are mades of interacting atoms).
