Faulty lamp because it short circuit
7 replies · 4K views · last reply
thoradicus
http://www.xtremepapers.com/papers/CIE/Cambridge%20International%20A%20and%20AS%20Level/Physics%20%289702%29/9702_s06_qp_2.pdf
number 7a
None really
The answer is that C is the faulty lamp because it short circuit. But how do I know it is faulty?
Im quite sure it has something to do with the last row: open closed closed 15 ohm
Just realized it was a 1 word title :/
The ohmmeter reads the resultant resistance between its terminals. Which lamp does it measure in the first case? So what is the resistance of one lamp? Which lamps are connected in series in the third case?
ehild
ehild
For the 1st case it measures no lamps?
The resistance for 1 lamp is 15ohm.
A and B?>
Sorry, I wanted to ask the first case when S1 is closed. But it is right, the resistance of one lamp is 15 ohm. In the third case, A and B are connected in series, the resistances add up, and the meter measures 30 ohm, which is the resultant of two lamps in series. So lamp B is not faulty.
How are the lamps connected in the fourth case? What is the resistance of C when the resultant is 15 ohm?
ehild
ehild
ummm in parallel? I am not sure
Is it 0 for C?
B and C are connected in parallel, and A is in series with the resultant of B and C. Yes, the resistance of C has to be zero.
ehild
Ok, so let me get this right
the current passes through A but also passes through C only, because it is faulty so it has 0 resistance, so it was shorted?
Yes. But a faulty lamp can have either infinite or zero resistance. If it is not shorted, the meter would read a resistance higher than 15 ohm. The measured resistance is 15 ohm, so leaving lamp A, the current goes through a short. Or: The resultant resistance of B and C in parallel has to be zero. That can happen only when C is a short (as B is not faulty).
ehild
