Femur Compression/Young's Modulus
7 replies · 16K views
Student in Need
By what amount does the 52-cm-long femur of an 73 kg runner compress at this moment? The cross-section area of the bone of the femur can be taken as 5.2×10-4 m2 and its Young'’s modulus is 1.6×1010 N/m2.
Express your answer to two significant figures and include the appropriate units.
Stress on femur = F/A
Strain = delta L/L = (1/Y)(F/A)
F/A = (73 kg * 9.8 m/ss)/(5.2 * 10-4 m2) = 1375769.231 N/m2
deltaL/L = (1/1.6×1010 N/m2)(1375769.231 N/m2) = 8.598557692 * 10-5
(8.598557692 * 10-5) * 0.52 m = 4.47125 * 10-5 m = 4.5 * 10-5 m
I'm not sure what I'm doing wrong; any help would be appreciated!
What makes you think you're doing anything wrong?
BTW, the femur is one of the biggest and strongest bones in the human body. It's not supposed to shrink or stretch very much under normal use.
Unless you're this guy:
This was a problem on MasteringPhysics and when I submitted this answer, it was incorrect. :(
Your problem statement seems to start in the middle. It's asking you to calculate by what amount the femur compresses "in this moment", but it is not clear what that means. Your calculation assumes that all the static weight of the runner is supported by one femur. Is that what the problem is really asking you? When someone is running, dynamic loadings on the legs can easily exceed the loads present when one is standing still.
There was also this bit of information in the problem that I assumed wasn't important:
"The normal force of the ground on the foot can reach three times a runner's body weight when the foot strikes the pavement."
Should I be multiplying the force by 3?
Well, what do you think? If the force is three times what it would be in a static situation, don't you think this affects by how much the bone will compress?
BTW, the Rules at PF ask that HW posters provide a "complete" problem statement. That way, you don't have to worry about what is or is not important, because the HW helpers are working from the same information as the HW posters, which is only fair.
Thank you! And I'll make sure I keep that in mind next time.
