How Is Angular Acceleration Calculated for a Speeding Ferris Wheel?
  • Thread starter Thread starter EthanVandals
    Accelerating Wheel
The discussion focuses on calculating the angular acceleration of a Ferris Wheel with a radius of 25 meters, which accelerates from a linear speed of 2 meters per second to 3 meters per second over 5 seconds. The angular acceleration is derived using the formula a = rα, where 'a' is linear acceleration, 'r' is the radius, and 'α' is angular acceleration. The participant also seeks to determine the time required for a complete rotation while the wheel continues to accelerate, applying the equation for linear distance s = rθ.
  • Understanding of linear and angular velocity
  • Familiarity with the equations of motion for circular motion
  • Knowledge of basic trigonometry and geometry related to circles
  • Ability to manipulate algebraic equations
  • Learn how to calculate angular acceleration using the formula α = (ω_f - ω_i) / t
  • Study the relationship between linear and angular quantities in rotational motion
  • Explore the concept of centripetal force in circular motion
  • Investigate the implications of angular acceleration on the time for a full rotation
Students studying physics, particularly those focusing on mechanics and rotational motion, as well as educators seeking to clarify concepts related to angular acceleration and circular dynamics.
EthanVandals
If a Ferris Wheel of radius 25 meters is sped up from a linear speed of 2 meters per second to 3 meters per second, what is its angular acceleration if it takes 5 seconds to do this? How long will it take to complete a complete circle if it continues to accelerate at this rate?
C = 2(pi)r
I imagine I could get the second half of this problem fairly easily once I get the first one because I just need to find 50pi and apply the acceleration to it. We've done problems talking about the force of the bars holding the cars up, and problems about centripetal force, but my professor specifically stated the day before spring break that he forgot to teach us about this, so he doesn't expect anything miraculous. I would still like to understand however. I mapped out the concept on a graph (with the velocity on the y-axis and the time on the x axis. If you look at how long it took for the wheel to actually increase its speed by just 1 m/s, you get a slope of 1/5. But how do you translate this into this "angular acceleration" language? And without calculus, is there a way to actually calculate how long a full rotation will take, since the time where it's undergoing its "change" in velocity is unaccounted for at the moment? Thanks!
These equations are valid when the units of angle are radians.
s = rθ (linear distance = radius times angle)
v = rω (linear velocity = radius times angular velocity)
a = rα (linear acceleration = radius times angular acceleration)
These are true for the same reason as the equation you cited: C = 2πr - that is, because the ratio of the circumference to radius of a circle happens to be 2 times π.
  • · Replies 33 ·
  • · Replies 21 ·
