Ferrite magnet as toroid transformer
This discussion focuses on the use of a ferrite magnet as a toroidal transformer to step up voltage from a 5V DC battery. Users highlight that transformers require AC signals to function effectively, and a ferrite magnet is not suitable for this application. Instead, a soft ferrite core is recommended for constructing a transformer. For stepping up voltage, a boost converter is suggested as a more efficient and practical solution.
  • Understanding of transformer principles and AC signal requirements
  • Familiarity with ferrite materials and their magnetic properties
  • Knowledge of boost converter circuits and their applications
  • Experience with basic electrical components and circuit design
  • Research "boost converter circuits" and their implementation for voltage step-up
  • Learn about "soft ferrite core materials" and their advantages in transformer design
  • Explore "synchronous rectification" techniques for improved efficiency in DC-DC converters
  • Investigate "Linear Technology's boost regulators" for practical applications in voltage conversion
Electronics enthusiasts, hobbyists, and engineers looking to design efficient voltage conversion circuits, particularly those interested in transformer applications and boost converter technology.
ramonegumpert
Dear Experts
I have a 1.5 cm ring magnet, you know, the black color type of common low magnetic power magnet.
I wrapped 5 turns of copper wire around it on one side and then wrapped 10 rounds of another copper wire around it . I connected 5v battery to the 2 ends of the primary coil which is the 5 turn winding.
I then measured with volt meter the secondary coil. I did not see the output voltage at the secondary coil increase.
This is my noobie attempt. Please comment what could be wrong.
Can a ferrite magnet be used to step up voltage?
I want to step up the voltage by around 2 volts.
Many Thanks.
regards
Ramone
Transformers only work on AC signals, so you would have to switch your battery current on and off through the primary winding to see anything on the secondary.
However, a ferrite magnet would be a poor choice for a transformer core. Better options would be normal ferrite or soft iron laminations from a transformer.
Dear Experts
So , what is the recommended way to stepup a 5v dc battery pack to 8volts, occupying minimal space? Kindly please offer me an idea.
I have sen videos demonstrating how a joule thief can light up a 3v led using just 1.5v. I wonder can this toroid be modified/ used as-is to function as transformer ?
Yes, i am using a toroidal fridge magnet.
its ferrite but permanently magnetised, i think. Is the effect different than a non-magnetised ferrite?
Cheers
ramonegumpert said:
Dear Experts
Use a boost converter, which are transformerless:http://www.linear.com/products/step-up_(boost)_regulators
Other mfgrs also make similar chips.
Magnets are not suitable for transformers.
Thanks so much Bob S. I will get a ferrite toroid and try again.
Cheers :)
If you need to make a toroid transformer circuit, be sure to use a soft ferrite. I personally would search for a boost regulator circuit from Linear.com, using a DIP package. How many milliamps do you need? I have built ferrite transformer circuits before, and the boost regulators are easier.
Dear Bob
Thanks for your reply.
I am looking at output of as high as 500 milliamps, input voltage of any between 9v to 12 v and output of 5.5 to 6v.
Is it possible to get free samples of 1 or 2 units for testing?
Thanks.
Regards
Ramone
You get free samples if someone thinks you might buy $500 worth of something. So, they ask who you work for and what your position is.
So, unless you are likely to buy a lot of something, you shouldn't ask for free samples.
Almost free, though, are these on Ebay:
http://www.ebay.com.au/itm/DC-DC-Converter-Buck-Step-Down-Voltage-Module-4-75-24V-0-93-18V-2-5A-Output-/270940113628?pt=AU_Gadgets&hash=item3f154a0adc
Synchronous rectification, Max efficiency up to 98%.
Input: 4.75-24V.
Output: 0.93V-18V ( Buck Mode, the input must be 2V higher than output ).
Output Current: continuous 2.5A ( Peak 4A).
Price about $3.50 US.
Which country are you in?
10K
  • · Replies 17 ·
  • · Replies 22 ·
