Fiber Optic Y Connection Question
Creating a Y-shaped connection with fiber optic wires is theoretically possible but practically challenging. A three-way fusion splice would require precise alignment of both angles and the crystal lattices of the fiber tips. While such splices are common in passive optical networks like Verizon's FIOS, they are not easily constructed by individuals. The idea of using a liquid with a matching refractive index to facilitate the junction is intriguing, as index matching gels are already used in fiber splicing. Overall, while innovative methods may exist, the complexity of achieving loss-less transmission remains a significant hurdle.
Physt
Is it possible to have a fiber optic wire spliced onto another (or starting from 3 separate fibers) to form a Y shape and have loss-less (or close thereto, as good as a normal splice) transmission from 2 of the fibers into the third? I know this wouldn't work for double-clad fiber or for single-mode fiber - but I'm wondering if setting a bunch of fiber lasers in a binary tree configuration to increase output power would be more practical than building a fiber disk laser (in terms of ease of the build, since a disk laser cavity requires some pretty precise mechanical tuning).
Science news on Phys.org
So you are asking if you can do a 3-way fusion splice?
I would say theoretically yes, practically no. Not easily anyway.
Claude.
Claude.
I'm guessing you would need to align the angles correctly, but would a 3-way fusion splice require the fibers to have the crystal lattices of their tips aligned as well, or just the angles?
You would not be able to build this yourself, but they are deployed in great volumes in passive optical networks (such as Verizon's FIOS).
I just had a thought, and might be incredibly wrong, but if not:
Could you use a liquid with the same refraction index as the doped fiber to create the junction?
I'm considering if you were to machine out a Y-shaped cavity with 3 holes, placed 2 fibers inside then filled with a similar refractive index fluid, then inserted the third fiber (perhaps submersed to prevent air bubbles).
Index matching gels or "optical gels" are routinely used for splicing fibers. Splitters and combiners is a whole different situation.
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
9K
