Fibonacci Sequence: 1, 1, 2, 3, 5, 8
  • Thread starter Thread starter gtfitzpatrick
    Sequence
gtfitzpatrick
the Fibonacci sequence is defined by
a1 = a2 = 1, a(n+2)] = an + a(n+1).
write out the first 6 terms of the sequence and prove that an = 1/[tex]\sqrt{5}[/tex][ ((1+[tex]\sqrt{}5[/tex])/2)^2 - ((1-[tex]\sqrt{}5[/tex])/2)^2]
the first 6 terms are 1,1,2,3,5,8 but from here where do i go proving this... totally lost
wait do i have to use the first 6 terms or do you think they just want me to prove it?
Thanks for any replies
You've got the first 6 terms just fine. To find the general solution look for power law solutions an=r^n of your recursion relation. Put an=r^n into your recursion relation and solve for r. You should get a quadratic and two solutions. What are they?
This can't be the right formula for an. It varies with n, while your formula above is a constant.
The characteristic equation is [tex]r^{2}-r-1=0[/tex]
The roots are [tex]\frac {1+ \sqrt{5}}{2} , \frac {1- \sqrt{5}}{2}[/tex]
The general solution is then [tex]a_{n} = \alpha (\frac {1+ \sqrt{5}}{2})^{n} + \beta ({\frac{1- \sqrt{5}}{2})^n[/tex]
Then use the initial conditions, namely a0=1 and a1=1 to find [tex]\alpha[/tex] and [tex]\beta[/tex]
