Einstein Field Eqns: East/West Coast Metrics
The discussion centers on the implications of metric choice on the sign of the cosmological constant (Λ) in the Einstein field equations. It is established that the relative sign between the Ricci scalar term and the Λ term is crucial, and this relationship remains unaffected by the chosen metric signature convention. The conversation highlights that while the 00 element of the equations can yield different results based on sign and metric, it lacks physical meaning when considered in isolation. The confusion surrounding sign conventions in General Relativity (GR) and Special Relativity (SR) is also addressed, emphasizing the need for clarity in academic papers.
  • Understanding of Einstein field equations and their components
  • Familiarity with metric signature conventions in General Relativity
  • Knowledge of Ricci scalar and Einstein tensor properties
  • Basic grasp of tensor calculus and its applications in physics
  • Study the implications of different metric signatures in General Relativity
  • Explore the role of the Ricci scalar in the Einstein field equations
  • Review the Misner-Thorne-Wheeler textbook for insights on sign conventions
  • Investigate the physical interpretations of the 00 element in the Einstein field equations
The discussion is beneficial for theoretical physicists, graduate students in physics, and researchers focusing on General Relativity and cosmology, particularly those navigating the complexities of metric signatures and their implications on physical interpretations.
DuckAmuck
TL;DR
Different results unless you are careful?
My questions is:
Depending on which metric you choose "east coast" or "west coast", do you have to also mind the sign on the cosmological constant in the Einstein field equations?
R_{\mu\nu} - \frac{1}{2} R g_{\mu\nu} \pm \Lambda g_{\mu\nu} = \frac{8\pi G}{c^4} T_{\mu\nu}
For example, if you stick with a +Lambda term with both metrics, you get different results for each metric. So once you choose a metric, you have to have the right sign on Lambda it seems.
No, you don't. Note that the Ricci scalar term also multiplies ##g_{\mu \nu}##, and the sign of the Ricci scalar term has to be negative (since that's the only way to get an Einstein tensor whose covariant divergence is zero). The relative sign of that term and the ##\Lambda## term is the key thing, physically speaking, and that isn't affected by which metric signature convention you choose.
This is what I thought at first. But if you take the 00 element of the equations, and the trace of the equations, and solve for Lambda, you get different results depending on your choice of sign and metric. Would just like some clarity on the sign conventions for this.
Why would you do that? The 00 element by itself has no physical meaning.
Maybe I'm not explaining it right. I swear I have seen this done before. Here is the process:
Start with this generic form:
R_{\mu\nu} - \frac{1}{2} R g_{\mu\nu} \pm \Lambda g_{\mu\nu} = \frac{8 \pi G}{c^4} T_{\mu\nu}
Take the trace to get:
-R \pm 4\Lambda = \frac{8 \pi G}{c^4} T
Take the time element (00 element) to get:
R_{00} - \frac{1}{2} Rg_{00} \pm \Lambda g_{00} = \frac{8 \pi G}{c^4} T_{00}
Where g_00 can be +1 or -1 depending on metric choice.
Treating these equations like a system, you can arrive at:
R_{00} \mp \Lambda g_{00} = \frac{8 \pi G}{c^4} (T_{00} - Tg_{00}/2)
Which doesn't matter because ##g_{00}## appears explicitly in the equations.
Yes. So what?
Note that in GR there are even more confusing differing sign convention than in SR. In SR you have essentially only two differing sign conventions: One in the Minkowski product which can be of signature (1,3) (west coast convention, usually used in the high-energy-particle physics community, but also there are exceptions, e.g., Weinberg) or of signature (3,1) (east-coast convention). The other is in defining the 4D Levi-Civita symbol. No matter how you start, in Minkowski coordinates you have ##\epsilon_{\mu \nu \rho \sigma}=-\epsilon^{\mu \nu \rho \sigma}## and different authors start with different definitions concerning the sign. It's very confusing. Most common seems to be ##\epsilon^{0123}=+1##. In any case one has to check the convention for each paper.
In GR you can get additional sign changes from different non-zero contractions of the Riemann curvature tensor to the 2nd-rank Ricci tensor, leading to sign changes. A nice review about different conventions can be found in Misner-Thorne-Wheeler (note that Landau&Lifshitz changed their sign conventions from one edition to the other of their vol. 2 ;-)).
  • · Replies 24 ·
  • · Replies 62 ·
  • · Replies 17 ·
