Field strength to deflect electron in a cathode-ray tube
The discussion focuses on calculating the magnetic field strength required to deflect an electron in a cathode-ray tube by 13 degrees after being accelerated through a potential difference of 10 kV. The initial velocity of the electron is determined to be 5.931×107 m/s. The participants clarify that the magnetic force acting on the electron is perpendicular to its velocity, necessitating the use of centripetal acceleration in the calculations. The correct formula for the magnetic field strength is derived as B = mv/rq, where 'r' is the radius of the circular motion, which depends on the magnetic field itself.
  • Understanding of cathode-ray tube physics
  • Familiarity with the concepts of electric potential and kinetic energy
  • Knowledge of magnetic forces and centripetal acceleration
  • Ability to manipulate equations involving velocity, mass, and charge
  • Study the principles of uniform circular motion in magnetic fields
  • Learn how to derive the radius of circular motion for charged particles in magnetic fields
  • Explore the relationship between magnetic field strength and particle deflection angles
  • Investigate the impact of varying potential differences on electron acceleration in cathode-ray tubes
Physics students, educators, and professionals involved in electromagnetism and particle physics, particularly those working with cathode-ray tubes and magnetic field applications.
David23454
An electron in a cathode-ray tube is accelerated through a potential difference of 10 kV, then passes through the d = 2.4-cm-wide region of uniform magnetic field in the figure(Figure 1) .
What field strength will deflect the electron by θ = 13 degrees?
[/B]
Δx=vt+0.5aΔt2
KE=0.5mv2
U=qΔV
F=qvBsin(θ)
F=ma
B=ma/qvsin(θ)
Ki+Ui=Kf+Uf
[/B]
Since Ki=0, then Kf=-ΔU
Since U=qΔV, then Kf=-qΔV
Since Kf=0.5mv2, then 0.5mv2=-qΔV
Using 0.5mv2=-qΔV, and inputing values 0.5(9.11×10-31)v2)=-(-1.60×10-19)(10,000)
So, v after acceleration by ΔV is 5.931×107 m/s.
Δx=viΔt+0.5axΔt2
Since ax=0, because the force should be acting to change only the ay
t=4.047×10-10 s
so, Δy=viΔt+0.5ayΔt2
and since Δy=0.024tan(13)=5.54×10-3
then, ay=6.765×1016
Since: F=qvBsin(θ) and F=ma, then
B=ma/qvsin(θ), and θ=90, (I think?)
so
B=(9.11×10-31)(6.756×1016)/(1.60×10-19)(5.931×107)=6.49×10-3 T
This answer is incorrect. Could someone show me where I went wrong? Thanks!
The magnetic force is perpendicular to the velocity. In F = q v B sinθ, θ = π/2. The angle that you seeking has to do with the circular arc of the electron's trajectory.
Right. I'm pretty sure I used π/2=90 degrees in my calculations. I'm trying to find the field strength needed to deflect the electron. Any idea where I went wrong in my calculations?
This is where you went wrong. What I am trying to say is that the electron undergoes uniform circular motion in he region of magnetic field. The acceleration is centripetal.
Oh, I think I see. So, the acceleration I should use to input into the equation B=ma/qv should be:
ac=V2/r
How would I calculate the "r" in the equation for centripetal acceleration?
The "r" depends on the magnetic field. Can you find an expression for it in terms of the magnetic field?
Ye
Yes, r=mv/qB, but since the magnetic field is what I'm trying to find, I'm not sure what I can do with it.
Remember that the electron is undergoing uniform circular motion. Can you write expressions for the x and y components of its position as a function of time? Note that at t = 0, the electron is at position {0, mv/qB} and moving with velocity {v, 0}.
Wait, I think I might be getting it, so the equation would look like :
since ac=v2/(mv/qB) then
B=m((v2)/(mv/qB))/qv
You are going around in a circle. This gives you B = B if you simplify.
ok
Please consider post #8.
x(t)=vx+0.5axt2 and y(t)=vyt+0.5ayt2
I know that I have to incorporate something relating to the fact that at t=0 where position is (0, mv/qB) and velocity is (v,0), but I'm not sure how to proceed.
Please forget the equations that you quoted. They are not pertinent to uniform circular motion. In uniform circular motion the object is going around a circle at constant speed. This would be the case here if the magnetic field extended over a larger region. Instead the particle exits the field, nevertheless while it's still in the field region, it moves at constant speed.
Try this approach. Draw a picture of the particle at the exit point and a vector from the center of the circle (remember it has radius mv/qB). The x-component of the position vector must be what?
The x-component of the position should be the length of box containing the magnetic field (xf-xi)=0.024 m, and the y-component of the position should be y=(0.024)tan(13).
Using geometry, I think the radius of the should be (Δx2+Δy2)/2Δy, which should be 0.05476 m. Then I should be able to put it in the formula B=mv/rq. Does this sound correct?
No.
Draw a diagram showing the arc of travel and the centre of the arc, joining the centre to the ends of the arc with two radii to form a sector.
What is the angle in the sector, i.e. between the radii?
In terms of that angle and the radius, what is the distance traveled along the x axis?
26K
  • · Replies 25 ·
  • · Replies 78 ·
