Final velocity of satellite that falls from orbit
The discussion revolves around a physics problem involving a satellite falling from orbit. The original poster presents a scenario where a satellite of mass 100,000 kg is released from rest at an altitude of 100,000 feet (later corrected to meters) and seeks to determine its final velocity before impact with the Earth, assuming no damping forces act on it.
  • Participants explore various equations related to gravitational potential energy and kinetic energy, questioning the applicability of these equations in the context of the satellite's fall. Some participants express confusion about the assumptions regarding gravitational acceleration and the altitude of the satellite.
The discussion is active, with participants providing insights and questioning each other's reasoning. Some have suggested using energy conservation principles, while others emphasize the importance of understanding the conditions under which specific equations apply. There is a mix of interpretations regarding the calculations and assumptions made.
Participants note the potential confusion between using feet and meters for altitude and the implications of using approximations for gravitational acceleration. There is also mention of the satellite's potential energy being relative to the Earth's surface rather than the center of the Earth.
jcruise322
Hey, how's it going! Just a little confused about how to do the problem below. Any help would be appreciated!
1. Homework Statement
A satellite of mass m=100,000 kg is moving around the Earth in a circular orbit at an altitude of 100,000 feet above the surface.
If the satellite were stopped and released from rest, what would its final velocity be before it hit the earth?
Assume no dampening force.
mv^2/r=G*M1*M1/r^2
mv^2/2=G*M1*M2/r
PE=mgh
KE=.5*m1*v^2
I used equation 2 on the list, plugged all the variables in, and got 11,094 m/s. I have no idea if it is correct however!
Regards,
JT
Try not to just insert things into formulas. This is not what physics is about. Physics is about using reasoning and logic to arrive at a result.
What does the second formula tell you? Why do you think it is applicable to this situation? What physical principles are you using?
Equation 2 relates the speed and the radius for a satellite in a circular orbit, but we're told the satellite is released from rest.
What happens when the satellite falls, is that all its potential energy is converted to kinetic energy.
No it doesn't. It is off by a factor of two. Equation 1 does so (by equating the centripetal force required with the gravitational force).
So...I will try to think about this in the most logical way, I guess. So, Earth and the satellite are part of the system. I am not sure if we can treat gravity's acceleration as equaling 9.81 m/s/s here...can we just use 9.8 as an approximation? Anyway, the satellite has PE at 100,000 meters proportional to the distance between the satellite and the center of mass of the earth. PE=G*M1*M2/r as stated in my physics textbook...this has to all be translated into kinetic energy at the Earth's core, (r=Radius of earth+altitlude of satellite) the formula being equal to .5m*v^2/2. however, using this formula this way assume that there is still PE when the satellite arrives at the earth. So, PE=KEf+mgh (mgh being at the Earth's surface; h=radius of the earth).
Sooooo...after plugging and chugging, I get 11,005.86 m/s as an approximation. That is really frigging fast, holy S***. Anyway, Halp? Orodruin, what do you think? Does this make sense?
Is the satellite orbiting at 100,000 feet (from the problem statement) or 100,000 meters? One altitude is in space, the other is within the upper atmosphere.
100,000 meters NOT feet! Sorry, I made a transcription error! Yup, this baby is in space, Streamking!
*Steamking...xD
This is only an approximation which is valid if the gravitational field is homogeneous and of the same strength as at the Earth's surface. You cannot apply it generally.
But the satellite is not reaching the core, it crashes into the surface first! Also, the potential with this definition is relative to infinity, not with respect to the center of the Earth! As a result of this, you are getting a number which is simply very close to the escape velocity, i.e., the velocity required to escape the Earth's gravitational field.
Exactly! Did you read all of what I said? I said that it didn't.
jcruise322 said:
PE=KEf+mgh
Anyway, if you think that I am wrong, please give me your opinion. I have done all that I can do for now.
Read the last part of Orodruin's post. Your equation 2 is for an object falling from infinity to radius r. There's no point memorising equations if you don't remember the conditions under which they apply and what the variables represent.
Think about the change in PE as it falls 100km.
Of course, 100km is quite small compared with the radius of the Earth, so gravitational acceleration won't change much over that drop. Using mgh would at least give you a fairly tight upper bound on the answer, useful as a check.
Yo, I think I got this figured out. I would use energy conservation.
Ei=Efinal.
The satellite only has potential energy when it is stopped given by-(G*m1*m2)/(r1). r1 equals radius of Earth + altitude.
If we ignore drag, part of this PE is converted into KE, .5*m*v^2, and the other goes into "potential energy" or more precisely, the work required to move a stationary object an infinite distance away from Earth at the Earth's radius r, so PEfinal=-(G*m1*m2)/r2. r2=radius of earth.
Plugging in my numbers and solving for V:
We geeeeet: 1390.1 m/s
Yata! There we go! :) I think this sounds more reasonable...right?
Sorry, my final equation is: -(GM1)/r1=.5*v^2-G(M1)/r2
Ei=Efinal.
Check it yourself using the tip I gave you in post #11.
Using mgh=.5*m*v^2
vf=1400 m/s.
Pretty close to 1390.1 :)
  • · Replies 16 ·
  • · Replies 39 ·
